what suspension set up are you running
I fitted GAZ GHA's, they are adjustable damping and coil overs, so far I have done a track day on them and used them on the road, with the damping set on the softest setting the ride is very good, not bouncy or harsh. When the damping is wound up towards hard it is hard but still well damped and not harsh. They are £552 from Larkspeed and easy to fit. GAZ called me after the order was placed and asked what the car would be used for? Track only, track and road or predominantly road, they then make the suspension to suit your use, service was excellent.
Adjuster.
Front and rears before fitting
Rear adjuster, bot quite sat down on as the car was elevated.
Rears fitted
Fronts fitted
On track, not set at the lowest, either.
Yes, R32 Eibach ARB's, 26mm front and 24mm rears, also had all wheel alignment down at Demon Tweeks with 1/2 a degree toe out for better track turn in, makes it pull left with road camber though but straight and true on track. Not an issue as car only gets driven to the track, used and then driven back home.
http://www.larkspeed.com/index.pl?a=i&p=2E40850010111
I also had to shorten the front drop links for the ARB as the were about 1/2 inch too long and made the ARB touch the wishbone, this was not a problem though, cut a piece out and sleeved the drop links then welded them back up  ;)
 You can see the sleeve on the second to last photo.
Edited by Swivelonit
