apparantly the main difference is the final drive ratio...but it could still do with being shorter (i think).
you need to speak to phatvr6 on the cgti forum, he's the vr6 gearbox expert (actually he's the vr6 expert full stop!).
i know that the best thing to do is get a gemini 6 speed conversion, with custom ratio's (the 6th gear is the same as current 5th gear, then every other gear is closer, and has a different final drive) and add a torque biasing diff...it's available from stealth racing. but its about £1700!!
if on a smaller budget, i think the best thing to do is change the fianl driver, and add the diff...still be at least £700 tho.
