Sticking / seating HT Leads in slots in engine cover.
The engine plastics that retain the leads should have little tabs to keep the leads secure, sometimes people install crazy ht leads that are 10mm and then file these out to help them fit, so if you now have standard diameter leads then they won't stay put. What leads do you have, and does your ht lead guides have the plastic retaining tabs ?
Club Chairman
Ah right, I've not noticed any tabs. I'll have a good look at lunch. The current leads look like a mixture of 4 OEM and 2 magnacore jobbies, about 7/8mm I'd say. I'll be buying a new matching set soon to keep things uniform. Thanks :)
