paceo 22 Posted January 19, 2014 Report Share Posted January 19, 2014 been like it a while now since changing the heater matrix on the golf mk3 vr6, ive tried the method of leaving it running with the header tank cap off squeezing all the water pipes but the heaters dont blow really warm air, its coldish still!! pipes to the matrix is one is hot and the other is warm, is there any other way of bleeding it out fully? Link to post Share on other sites
mattvr6 133 Posted January 19, 2014 Report Share Posted January 19, 2014 First thing id do is make sure u have a good flow of coolant have u changed the stat? Sent from my iPhone using Tapatalk Link to post Share on other sites
daveyboy 897 Posted January 19, 2014 Report Share Posted January 19, 2014 Mine's exactly the same so I'm interested in what your suggestions are too. Sorry for jumping in on your thread paceo Link to post Share on other sites
Lukey. 381 Posted January 20, 2014 Report Share Posted January 20, 2014 Sounds like an airlock, try pointing the car up a really steep hill maybe the air will flow out then as air will always want to rise Nex 1 Link to post Share on other sites
daveyboy 897 Posted January 20, 2014 Report Share Posted January 20, 2014 I had mine up as high as I could get it on axle stands when I bled it and still no differenceSent from my LT26i using Tapatalk Link to post Share on other sites
paceo 22 Posted January 20, 2014 Author Report Share Posted January 20, 2014 (edited) Sounds like an airlock, try pointing the car up a really steep hill maybe the air will flow out then as air will always want to rise is there some sort of machine that can sort it out? was fine before the matrix change Edited January 20, 2014 by paceo Link to post Share on other sites
Lukey. 381 Posted January 20, 2014 Report Share Posted January 20, 2014 Mine had an air bubble in it for ages and you could hear it gurgling especially when the engine was off and the after run pump was on, then one day it managed to blurb itself out of the matrix an the noise disappeared. Link to post Share on other sites
paceo 22 Posted January 21, 2014 Author Report Share Posted January 21, 2014 still need a solution though? Link to post Share on other sites
paceo 22 Posted January 21, 2014 Author Report Share Posted January 21, 2014 would the thermostat be an issue? Link to post Share on other sites
Therusterman 59 Posted January 21, 2014 Report Share Posted January 21, 2014 Is the thermostat new? In the past with other golfs, after driving the car/getting it hot I left the reservoir cap off overnight to allow any air in the system out. Link to post Share on other sites
daveyboy 897 Posted January 22, 2014 Report Share Posted January 22, 2014 I know what's wrong with mine. My head gasket is f#*ked. Looks like I've got a leak between a water jacket and a pot Sent from my LT26i using Tapatalk Link to post Share on other sites
paceo 22 Posted January 22, 2014 Author Report Share Posted January 22, 2014 Is the thermostat new? In the past with other golfs, after driving the car/getting it hot I left the reservoir cap off overnight to allow any air in the system out. old dude! Link to post Share on other sites
Therusterman 59 Posted January 22, 2014 Report Share Posted January 22, 2014 Hmmmm, there is a chance it could of failed and stuck shut, but in my mind that would be a long shot. Suppose you could whip out the thermostat, run the car up to temperature and see if it warms up properly? Link to post Share on other sites
Lukey. 381 Posted January 22, 2014 Report Share Posted January 22, 2014 put the thermostat in a pan with a thermometer and boil it, according to the internet it should open at 80C Link to post Share on other sites
VR6Pete 1,455 Posted January 25, 2014 Report Share Posted January 25, 2014 I know what's wrong with mine. My head gasket is f#*ked. Looks like I've got a leak between a water jacket and a pot Sent from my LT26i using Tapatalk Nooooooo Club Chairman Link to post Share on other sites
VR6Pete 1,455 Posted January 25, 2014 Report Share Posted January 25, 2014 If you've had dash out - are your Bowden cables operating correctly? When I did my matrix the flaps / cables were not operating correctly which resulted in coolish air coming through. Club Chairman Link to post Share on other sites
paceo 22 Posted January 25, 2014 Author Report Share Posted January 25, 2014 If you've had dash out - are your Bowden cables operating correctly? When I did my matrix the flaps / cables were not operating correctly which resulted in coolish air coming through. Club Chairman they seem all connected! when i turn to cold its proper cold! when i turn to hot its slightly warm! Link to post Share on other sites
daveyboy 897 Posted January 25, 2014 Report Share Posted January 25, 2014 Nooooooo Club Chairman Tell me about it just done a sniff test on it today and its 100% cattled Sent from my GT-N8010 using Tapatalk Link to post Share on other sites
