right then ... drivers side bottom arm?
im sure its been covered ,  but wen you remove the front bolt on the drivers side bottom arm  it fouls the sump ... so is it a case of removing the rear mount to enable the engine to swing n it gives you the room or is there a knack ?  i have to remove my sump anyways to re seal it as there is a leak n its been bodged but for future reference would be nice.
