daveyboy 897 Posted February 2, 2014 Report Share Posted February 2, 2014 Am I right in thinking that this is odb1? I've got 2 timing chains (pic to follow) Link to post Share on other sites
daveyboy 897 Posted February 2, 2014 Author Report Share Posted February 2, 2014 Sent from my LT26i using Tapatalk Link to post Share on other sites
mattvr6 133 Posted February 2, 2014 Report Share Posted February 2, 2014 Yea Sent from my iPhone using Tapatalk Link to post Share on other sites
VR6Pete 1,455 Posted February 2, 2014 Report Share Posted February 2, 2014 Not all obd2's had a single chain, absolutely no real differences with the actual engine. It's things like MAF, manifold, throttle body, lambda, ECU that are the differentiating features between obd1 and obd2 Club Chairman Link to post Share on other sites
daveyboy 897 Posted February 2, 2014 Author Report Share Posted February 2, 2014 See mines on the change over the car is a 96 N. That's why I was askingSent from my LT26i using Tapatalk Link to post Share on other sites
Therusterman 59 Posted February 2, 2014 Report Share Posted February 2, 2014 (edited) Check out the engine number, anything up to number 176889 will have double chains, as has been said, some obd 2 cars could still have this Edited February 2, 2014 by Therusterman Link to post Share on other sites
VR6Pete 1,455 Posted February 2, 2014 Report Share Posted February 2, 2014 Ah, my 1997 was single top chain, only seemed the late late ones had single top chain Club Chairman Link to post Share on other sites
ssaunders 199 Posted February 2, 2014 Report Share Posted February 2, 2014 Hi I think it was engine number aaa217001 and up was single chain. It's best to use the later guide which I believe is compatible with earlier chains.S Link to post Share on other sites
Lukey. 381 Posted February 2, 2014 Report Share Posted February 2, 2014 217000 was the switch over for single chain, if you get the slider from VW yet will only sell you the latest version one. Link to post Share on other sites
daveyboy 897 Posted February 3, 2014 Author Report Share Posted February 3, 2014 Surely having 2 cam chains will be better than having 1. Less pressure on each chain than just having a single chainSent from my LT26i using Tapatalk Link to post Share on other sites
daveyboy 897 Posted February 3, 2014 Author Report Share Posted February 3, 2014 So what should I look for to know if it's a 1 or a 2 when it comes to maf and throttle body etc?Sent from my LT26i using Tapatalk Link to post Share on other sites
GordonC 20 Posted February 3, 2014 Report Share Posted February 3, 2014 You can tell by the throttle body mate obd1 has a square block on the top where the coolant pipes connect to, obd2 has a circle on the top above the coolant pipes. Heres a link with pictures of them http://www.vr6oc.com/forum/topic/7902-is-my-vr6-an-obd1-or-obd2/VR6 Loonibuggy Santa Pod 2014 ! Link to post Share on other sites
daveyboy 897 Posted February 3, 2014 Author Report Share Posted February 3, 2014 Well it looks like mine is a bit of both Gordon lol my throttle body is obd2 as is the bodyworkSent from my LT26i using Tapatalk Link to post Share on other sites
MJ Vr6 79 Posted February 4, 2014 Report Share Posted February 4, 2014 Ah, my 1997 was single top chain, only seemed the late late ones had single top chain Club ChairmanAfter the 96 model, 97 adapted back to single chain mate.Same with the usage in Petrol.If you look at the petrol flap it should state Unleaded on yours Pete, were mines was 1996 stated Super Unleaded. Link to post Share on other sites
MJ Vr6 79 Posted February 4, 2014 Report Share Posted February 4, 2014 See mines on the change over the car is a 96 N. That's why I was askingSent from my LT26i using Tapatalk1995 was a change over believe it or not.A mate had an M reg Mulberry Highline.Square side repeaters on wings.Ran on C/P but had Early Inlet. Link to post Share on other sites
Lukey. 381 Posted February 4, 2014 Report Share Posted February 4, 2014 My 97 fuel sticker says super unleaded on it Link to post Share on other sites
MJ Vr6 79 Posted February 4, 2014 Report Share Posted February 4, 2014 My 97 fuel sticker says super unleaded on itWow, thats a 1st!! VR6Pete 1 Link to post Share on other sites
