kent cams on VR6 engine 12v
Hi,
Kent Cams have been around for years, back in the day of mk2 escorts and xr2's more fordy than VW but a good make.
I don't know anyone running them on a VR let us know how they go.
Good luck
S
Specs are (courtesy of kentcams.com)
Applications Sports Injection
Power Band 2000-6500
Cam Lift(mm) 10.94mm Inlet/Exhaust
Valve Lift(mm) 10.94mm Inlet/Exhaust
Duration 264 Deg Inlet/Exhaust
Timing 22/62 62/22
Full Lift Inlet 110 Deg ATDC/Exh 110 Deg BTDC
VC (mm) 0.00mm Inlet/Exhaust
LTDC 1.65mm Inlet
Edited by ssaunders
In 2003 i bought a set of Kent 264 cams for my 1992 Corrado VR6.Around £350 for them back then. Complete Supersprint exhaust w/header.No software. Gain ? Yes, but not that much. But im not a fan of n/a tuning on VR6s. The gain is not worth it compared to the price it costs.
Quality of the cams are good. On a roller i guess you can see some gains.
264 lift is fine.
I would bought them again.
Edited by MaidenVR6
i mean £220 for the kent cams i cant find cams cheaper than 550 euros for schimmel cams or schrick
Hi Mate, new they should be £450 odd, sure that your not looking at the reprofiling of your originals? that works out about 225?
Kent "Sports" cams are for Fast Road applications - no other mods are required. "Sports R" cams will produce more power but Kent recommend that you also fit a performance exhaust, air filter and a chip. The "Sports" cams will idle better than the "Sports R" cams and will be 'better behaved around town'. The "Sports R" cams need to be 'worked harder', having a higher rev range.
After each cam or cam kit are the letters Ex, O/R or BL. Their meanings are as follows: Ex - Exchange camshaft - you need to send your standard camshaft to Piper for reprofiling. O/R - Outright sale - The cam you will receive has been reprofiled from a standard cam - you do not need to send in your old cam. BL - Blank - The new cam is machined from either a new casting or a steel billet, so it is brand new.
camshafts2.gifIf you have seen cheaper elsewhere and you want us to beat it please click on the item then use the 'Seen it Cheaper' button at the bottom of the next page. Please note that our prices include VAT. Not everyone's do!
Application RRP
inc VAT Our
Price MSW
Quick Code Cam Kit - Sports Injection - BL £651.60 £605.99 38C65 Cam Kit - Sports Injection - Ex £402.00 £373.86 38C64 Cams - Sports Injection - BL £542.40 £504.43 38C63 Cams - Sports Injection - Ex £264.00 £245.52 38C62
Edited by ssaunders
  • 3 months later...
Don't know many people who have had these, I really rate the schimmel 263's though :) Club Chairman
Sorry to hijack here but Im looking to upgrade the cams on my vr while im rebuilding the engine and i've been searching the forum for answers :)
can i ask Pete why you rate the schimmel 263's? whats different about them to a 268?
Ive been thinking of some 268's but of what brand im not quite sure nothing extremely expensive tho. What gains could i expect with 263's and 268's also what else should be replace? Valves? Springs? Tappets?
Cheers man :)
  • 4 weeks later...
