Vince12v 20 Posted February 9, 2014 Report Share Posted February 9, 2014 How much work/ getting is it to swap out the 12v vr6 for the mk4 24v?? Sent from my iPhone using Tapatalk Link to post Share on other sites
Daverse 175 Posted February 9, 2014 Report Share Posted February 9, 2014 Engine (obviously) could use o2j gearbox or a 24v gearbox with a UM or custom mount. Think rear engine mount is different too. And loom and ecu. Depending what gearbox you use you will also need 24v thermostat housing, starter motor. A few people have done it on here so they should be able to write out a list for you Sent from my GT-I9300 using Tapatalk Link to post Share on other sites
Sean_Jaymo 11 Posted February 9, 2014 Report Share Posted February 9, 2014 02A gearbox bolts straight on as does the starter motor along with all the mounts. The holes for the rear mount are on the 24v block already, they will just need cleaning out with a tap. You can also keep the 12v thermostat housing and the rest of the pipe work. You literally just swap the block over and wire it up. There is tonnes of info on the Corrado forum. The Corrado and Mk3 both use the same (for all intents and purposes as far as bolting the engine in) subframes, wishbones, gearbox etc. Only major difference is the front cross member. The mounting points are the same on the cross member, just the shape is a bit different where the cross member bolts onto the car. Link to post Share on other sites
Vince12v 20 Posted February 9, 2014 Author Report Share Posted February 9, 2014 Can I use the 12v wiring? Sent from my iPhone using Tapatalk Link to post Share on other sites
cornishvr6 52 Posted February 9, 2014 Report Share Posted February 9, 2014 You need to use a combination of 12v and 24v looms and splice them together to create a bespoke loom :-) Link to post Share on other sites
Vince12v 20 Posted February 11, 2014 Author Report Share Posted February 11, 2014 Oooooooo bespoke!!! Lol Link to post Share on other sites
k4na.x 0 Posted February 23, 2014 Report Share Posted February 23, 2014 Just as an add on, the corrado needs the rear engine mount trimming by 15-20mm is this the same for the mk3? Link to post Share on other sites
shawy 3 Posted February 23, 2014 Report Share Posted February 23, 2014 Got a mint 24v engine here £500 Link to post Share on other sites
