the smallest adapters you will get are 15mm so that would make an et of 18. 195/45/16 tyres will be fine on a 7" rim but you may need to roll the rear arches depending on how low you are.
I'm running 6.5x16 on mine with et22 & 205/45/16 tyres. the rears need rolling & the fronts catch on the inner arch liner but that's it. I'm running -60mm springs though.
Ive got a set of 195/40/16 here in the shed so more than likely they will be going on, the car as it stands isnt too low on the 15 inch soltitudes, not sure how low or if it even is at all too be honest.
So the offset on 15mm adaptors will be fine to run?
cheers
Edited by jamesw6810
When you but the adapters they come with the bolts to bolt up to the hubs. I think merc wheel bolts are the same thread but can't remember. You'll probably be best ordering the correct shorter bolts when you order the adapters. I think standard bolts have 25mm of thread on them but as you're going to be using 15mm thick adapters you'll need shorter bolts.
On the ones I had the bolts from my Golf fit fine but I think they changed the hole size in the wheels to 14mm at some point so until you get the wheels you won't know but the good thing is the bolts from your golf will fit but will need cutting down for the adapters.
It's better to buy new bolts though once you have the adapters so that you know they fit in them.
