Rising rate presure regulator
Ok so I know most of you want to probly want to drop elbow me in the face for asking such a question. But what units are out there that do the job well? I see good results from begi units. I belive from back in the day Sard was a good aswell?
Also when plumming them in its done on the return line back to the tank? And does this mean that it replaces the standard presure regulator which is in the fuel rail from factory? If so what do you do with the unit on the rail? Remove it and blank it off? Or leave it in situ without a vac line? Cheers guys will be intrested to here from you.
