Radodb 4 Posted February 11, 2014 Report Share Posted February 11, 2014 right lads iv got the chance of a OBD2 2.9 corrado engine, box, loom, ecu the works and i can also get a cheap mk3 2.0 8v GTI iv got a few questions,is the obd2 2.9 good to turbo iv read up that the bottom end is not as strong as the 2.8also I'm guessing it will just be a case of plug and play with the loom into the mk3 GTI loom is this the case?? all in this will only be costing me £500 and i really think its worth it with the body work on the mk3 being very good with no real rust, in jazz blue with colour concept blue leather interior that i could sell and iv already sold the 8v engine haha.. Link to post Share on other sites
Marneus 78 Posted February 11, 2014 Report Share Posted February 11, 2014 It won't be plug & play by any means. You'll also need the gearbox & all hydraulic pipes for the clutch as the 8v will be cable clutch & rod shift. Also you'll need the VR6 engine loom. I bought a VR6 rather than convert my old 8v, it's far, far cheaper. Link to post Share on other sites
Radodb 4 Posted February 11, 2014 Author Report Share Posted February 11, 2014 the conversion comes with everything, peddle box, hydro line, shafts, gearbox, loom, ecu, transponder, shifter cables and tower the works. its costing me £300 for the mk3 and £200 for the full conversion from a friend, i can sell the leather interior and 8v engine that itself pays for the mk3.. as it comes with everything i won't need to buy much extra if anything. my only real question with the conversion is if the 2.9 vr loom will plug into the 8v fuse box iv done 2 Vr conversions on mk2 golfs but unsure how i stand with the mk3 fuse box i carnt see it being any different to the vr fuse box Link to post Share on other sites
JoboyVR6 0 Posted February 11, 2014 Report Share Posted February 11, 2014 How much the turbo costing you I'm after 1 Link to post Share on other sites
Radodb 4 Posted February 11, 2014 Author Report Share Posted February 11, 2014 Iv already got 90% of the turbo parts the engine conversion above dose not include the turbo build haha that's a silly amount more lol Sent from my iPhone using Tapatalk Link to post Share on other sites
Russ_vr6 12 Posted February 11, 2014 Report Share Posted February 11, 2014 I was under the impression all corrado's are obd1 Link to post Share on other sites
Radodb 4 Posted February 11, 2014 Author Report Share Posted February 11, 2014 It's rocking a coil pack so I guessed it was OBD2.... Sent from my iPhone using Tapatalk Link to post Share on other sites
mattvr6 133 Posted February 11, 2014 Report Share Posted February 11, 2014 They did obd1 with a coil pack the throttle body will give it away if there's a black unit on the side it's a obd2 and should have only 1 timing chain not 2 like obd1s Sent from my iPhone using Tapatalk Link to post Share on other sites
chrisvr6t 19 Posted February 11, 2014 Report Share Posted February 11, 2014 Obd1 run a isv next to throttle body Sent from my iPhone using Tapatalk Link to post Share on other sites
GordonC 20 Posted February 11, 2014 Report Share Posted February 11, 2014 All 2.9 corrados were OBD1 mate they stopped production of the corrado when they switched to OBD2VR6 Loonibuggy Santa Pod 2014 ! MJ Vr6 1 Link to post Share on other sites
MJ Vr6 79 Posted February 13, 2014 Report Share Posted February 13, 2014 All 2.9 corrados were OBD1 mate they stopped production of the corrado when they switched to OBD2VR6 Loonibuggy Santa Pod 2014 ! Link to post Share on other sites
