dellboy89 0 Posted February 14, 2014 Report Share Posted February 14, 2014 My vr6 is on it's way out , it's currently a 2.8 I was wondering if I change it to a 2.9 is it a different loom ? Link to post Share on other sites
damian8588 11 Posted February 14, 2014 Report Share Posted February 14, 2014 Not100% sure but depends weather your 2.8 is obd1 or obd2 if im correct if its obd1 it should be same loom as all 2.9 are obd1 anyone please correct me if im wrong Sent from my GT-I9100 using Tapatalk Link to post Share on other sites
mattvr6 133 Posted February 14, 2014 Report Share Posted February 14, 2014 Some obd1s were coil pack so if urs is the earlier type u should b ok Sent from my iPhone using Tapatalk Link to post Share on other sites
abvsean 32 Posted February 14, 2014 Report Share Posted February 14, 2014 thought the mk3 .2.8 were obd2?you could use the 2.9 engine and convert it to obd2 for better tunability using certain parts from the odb2 car from my understanding Link to post Share on other sites
damian8588 11 Posted February 15, 2014 Report Share Posted February 15, 2014 If im correct the change over point was 1995/6 from obd1 to obd2 I own a mk3 m reg obd1 coil pack earlier obd1 where different think its called dizzy Sent from my GT-I9100 using Tapatalk Link to post Share on other sites
mattvr6 133 Posted February 15, 2014 Report Share Posted February 15, 2014 As above early was dizzy like raddo's the later ones were better and Had more power 185/190 Bhp Sent from my iPhone using Tapatalk Link to post Share on other sites
GordonC 20 Posted February 15, 2014 Report Share Posted February 15, 2014 Unless your 2.8 is OBD2 then its the same wiring loom and you dont need to change itVR6 Loonibuggy Santa Pod 2014 ! Link to post Share on other sites
sedge 7 Posted March 5, 2014 Report Share Posted March 5, 2014 I'm running a mk2 vr6 that was converted using a mk3 set up which was running OBD2. About a year ago i swapped the engine out for a corrado 2.9 block.Kept all the auxilleries, inlet manifold, coilpack and electrics from the OBD2 that was already in the car and bolted it straight up to the 2.9 blockIs running no problem at all. Link to post Share on other sites
Mk1 Vr6 james 103 Posted March 25, 2014 Report Share Posted March 25, 2014 Is there much power gains by running the 2.9? Link to post Share on other sites
CALICO 130 Posted March 26, 2014 Report Share Posted March 26, 2014 10bhp Link to post Share on other sites
mattvr6 133 Posted March 26, 2014 Report Share Posted March 26, 2014 Obd2 normally put our 185/190 anyway got better management Sent from my iPhone using Tapatalk Link to post Share on other sites
