damian8588 11 Posted February 22, 2014 Report Share Posted February 22, 2014 Hi its come to that time where im going to do the timing chains been looking through some posts and cant work out which part numbers I need can anyone help Im looking for all the part numbers for the chains tensioner s ect.. I own a mk3 golf 1995 with obd1 coil while im there any thing else I should do /change any advice is much appreciated many thanks damian Sent from my GT-I9100 using Tapatalk VR6Pete 1 Link to post Share on other sites
Jakeyb 23 Posted February 23, 2014 Report Share Posted February 23, 2014 if you ring up VW or TPS car parts and ask if they could help you, if you give the chassis number they will tell you what parts numbers are specific to your chassis code. OBD1 will be twin top chains if im not mistaken . my personal choice would be to buy OE if you can or at least make of very highly quality as its not a job youd want to do again twice in a hurry .. check the timing case covers aswell as people have a tendency to over tighten bolts in them and strip threads and casues oil leaks. plus get a new rear main seal Link to post Share on other sites
Lukey. 381 Posted February 23, 2014 Report Share Posted February 23, 2014 If your clutch is old it's the obvious time to replace that aswell as you'll be removing it all anyway. Link to post Share on other sites
damian8588 11 Posted February 23, 2014 Author Report Share Posted February 23, 2014 Thanks guys will give tps an vw a ring Sent from my GT-I9100 using Tapatalk Link to post Share on other sites
Lukey. 381 Posted February 23, 2014 Report Share Posted February 23, 2014 (edited) TPS will be vastly cheaper if you can get any of your local ones to do a trade cash collection.Just to prepare you, it will be in the hundreds for all parts. Edited February 23, 2014 by Lukey. VR6Pete 1 Link to post Share on other sites
MK4motionVR6 41 Posted February 23, 2014 Report Share Posted February 23, 2014 This is quite a good site for pulling part No.. http://m.rexbo.eu/vw/golf-iii-1h1-91/2-8-vr6-17321/engine-timing-control-100003 Mk4motionVR6 Link to post Share on other sites
MK4motionVR6 41 Posted February 23, 2014 Report Share Posted February 23, 2014 http://www.vr6oc.com/forum/index.php?/topic/32712-Timing-Chain-Part-numbers%2E Mk4motionVR6 Link to post Share on other sites
