Vince12v 20 Posted March 1, 2014 Report Share Posted March 1, 2014 Has anyone got any advice on swapping out the rear beam bushes on a mk3!?I've been told to steer clear of poly bushes, an stuck with oem spec, and does any one got any good ways of gettin the out? Link to post Share on other sites
Liam Potts 4 Posted March 3, 2014 Report Share Posted March 3, 2014 What were the reasons for being advised away from poly? Just curious I'm running them and have fitted and driven a few on the vag platformsRemoval~ I burn the rubber out then cut a small incision into the outer sleeve and fold it in on itself, just falls out of the axle then. Installation~ ensure the axle is cleaned up prior. poly are nice and easy to fit just slot in by hand with a bit of rubber grease. OE spec stuff you'll be needing to borrow the installation tool to press it in without damaging it, they're an oddball shape to be making things for Sent from my iPhone using Tapatalk Link to post Share on other sites
andymk312v 15 Posted March 4, 2014 Report Share Posted March 4, 2014 As above poly all the way just for ease of fitting. Link to post Share on other sites
GordonC 20 Posted March 4, 2014 Report Share Posted March 4, 2014 I would deffinitly advise using polybushes they are much easier and quicker to put in and then you know they wont ever need done again. They dont make that much of a difference to the car other than tighted up the back end but its not majorly noticable. The front however is a different story. I personally wouldnt fit polys to the front of a road going car again as it was a bit to harsh for everyday use I think.VR6 Loonibuggy Santa Pod 2014 ! Link to post Share on other sites
Lukey. 381 Posted March 4, 2014 Report Share Posted March 4, 2014 I love mine on full polys its so direct and reactive Link to post Share on other sites
GordonC 20 Posted March 4, 2014 Report Share Posted March 4, 2014 Yeah it was good on full polys on a track but the roads are really bad up here and they just made it so much worseVR6 Loonibuggy Santa Pod 2014 ! Link to post Share on other sites
sedge 7 Posted March 5, 2014 Report Share Posted March 5, 2014 I just poly bushed the whole golf at the weekend ( well got the front crossmember left to do) If you dont want set fire to them with the rear axel attached to the car I used various sized sockets (quite big) and a clamp to press out the metal pin through the middle of the old bush and then as said before just hack away at the last bits of rubber and sleeving. But if your going through it with a saw be careful not to hit the actualy beam too much. Link to post Share on other sites
Lukey. 381 Posted March 5, 2014 Report Share Posted March 5, 2014 I did mine with the beam still on drilling the rubber out then cutting a section out of the sleeve with a hacksaw, then the metal sleeve could crush down and pop right out. mattvr6 1 Link to post Share on other sites
