Air flow sensor sensor compatibility
Go to solution Solved by isobarboy,
Sorry if been up. Before but I couldn't find any info.
I had maf sensor with the 3mm wide plastic strips running on where the sensor is.
That's broke.
So brought a new maf.
This one's with the 2 wires.
Question is;
1. Will if physically fit into the same spot?
2. Will it work the same?
Kind regards all.
