wolfsberg vr6 0 Posted May 17, 2005 Report Share Posted May 17, 2005 got myself a set at inters fitted them yesterday and buggerd all the clocks cos the last owner had superglued the needles to the brass bits inside so got a new set o clocks coming any tips on how to fit em dont want another set of broken clocks Link to post Share on other sites
pete8tch 0 Posted May 17, 2005 Report Share Posted May 17, 2005 very carefully iain, Link to post Share on other sites
wolfsberg vr6 0 Posted May 17, 2005 Author Report Share Posted May 17, 2005 if they didnt look so good i would just bin em surley some one has some tips for me on how to fit these bad boys Link to post Share on other sites
pete8tch 0 Posted May 17, 2005 Report Share Posted May 17, 2005 ask binliner he will have done it , he has stainless dials now i think, Link to post Share on other sites
binliner 0 Posted May 17, 2005 Report Share Posted May 17, 2005 1.get your clocks out and take apart (which you obviously already know how to do) make a note or take a pic of where the dials sit and how they move before taking them off2. get 2 small screwdrivers or better still butter knives and use them to carefully lift the needles off... dont put too much pressure they'll feel stuck but be patient and they'll come off3. Offer the new ones in position... I had to drill out the centres on the 2 large ones to make them fit better... compare the position of the marks on the speedo to make sure theyre the same4.Remove the OE dials and stick the new ones in place5. Carefully put the needles back on and check that they rest in the same position and move freely6. Bung it all back together and turn the key to see if they work7. Take the clocks out again because one of the needles wont be working right or in the right place8. Take the clocks out again because you'll have seen a fingerprint on the inside of the plastic!9. Repeat 6, 7 & 8 for about half an hour until you are totally happy Link to post Share on other sites
pete8tch 0 Posted May 17, 2005 Report Share Posted May 17, 2005 see told you he would know!!!! also repeat when you left it all day to rebuild the dash so you can see the blue leds are workin which they do so u rebuild only to discover the temp needles on the wrong side of the stop Link to post Share on other sites
wolfsberg vr6 0 Posted May 17, 2005 Author Report Share Posted May 17, 2005 cheers binliner i think ill just have to give it another go and hope for the best aaron from prem told me to switch on the ignition and mark were the fuel was what i dont understand is do u stick that needle back on with the ignition on cos the needle aint workin now and i did everything he told me to dohad an idea how about i back them in a box and send them to you binliner with a crisp twenty inside and u could do it for me 8) Link to post Share on other sites
nickbee 1 Posted May 17, 2005 Report Share Posted May 17, 2005 Yes mate, the mechanism will be in a different position when the igntion is on, so having re-fitted it with the ignition off yours is now in the wrong place! Link to post Share on other sites
binliner 0 Posted May 17, 2005 Report Share Posted May 17, 2005 I found with the petrol dial if you fit it and turn it to the left until you feel resistance (ie the resting point) then take the needle off and keeping the pin in the same place refit the needle so it points to empty. Then when I plugged the clocks back in and turned on the ignition the needle moved to the correct position... worked for me Link to post Share on other sites
wolfsberg vr6 0 Posted May 17, 2005 Author Report Share Posted May 17, 2005 does ur dials have the stops on them for the needles to rest on Link to post Share on other sites
MSV83 0 Posted May 17, 2005 Report Share Posted May 17, 2005 any 1 know where to get these dials....and how much Link to post Share on other sites
nickbee 1 Posted May 17, 2005 Report Share Posted May 17, 2005 They don't make them any more so ebay is your best chance, but don't hold your breath. Think £60 - £70. Link to post Share on other sites
pete8tch 0 Posted May 17, 2005 Report Share Posted May 17, 2005 ha i would be happy with lockwood but they dont do em that start at ten, so new clocks and dials is a bit ott Link to post Share on other sites
wolfsberg vr6 0 Posted May 17, 2005 Author Report Share Posted May 17, 2005 wanted 80 notes for them at inters Link to post Share on other sites
wolfsberg vr6 0 Posted May 18, 2005 Author Report Share Posted May 18, 2005 got the dials done today cheers pete and binliner for all ur help here are the bad boys fitted and workin Link to post Share on other sites
pete8tch 0 Posted May 18, 2005 Report Share Posted May 18, 2005 well done mate, Link to post Share on other sites
MSV83 0 Posted May 19, 2005 Report Share Posted May 19, 2005 they look sick mate..very jealous Link to post Share on other sites
wolfsberg vr6 0 Posted May 19, 2005 Author Report Share Posted May 19, 2005 cheers boys pity i wrecked the first set o clocks not all a loss tho new clocks only have 103 thousand miles much better than my 128 lol Link to post Share on other sites
