djmac 1 Posted April 8, 2014 Report Share Posted April 8, 2014 Hi, just drove my car and had to stop quite quickly, im guessing its the clutch but im not sure! The car sets off fine and i can find all gears, but when im in second gear and i cruise along at say 15mph, the car feels like its being stopped by something and i think theres a clicking noise coming back up through my clutch pedal, i dont dare take it for a real test drive in case it completely goes, Im sure the thrust bearing was making a whering noise a while back, but the fact it stopped made me forget about it? Could the thrust bearing be nackered? ill obviously change the full kit if its looking like the clutch area?Any advice would be great, Thanks Alot Dan Link to post Share on other sites
Reaperx 181 Posted April 8, 2014 Report Share Posted April 8, 2014 Sounds more like a gearbox failure to me if it only does it 2nd. If the clutch is going you will find the car is down on power in every gear and slipping would cause it to rev a lot more. If its the thrust bearing start the car leave it in neutral and press your clutch you should feel judder through the pedal without having to engage a gear. p0u1 1 Link to post Share on other sites
Lukey. 381 Posted April 8, 2014 Report Share Posted April 8, 2014 good clutch test is to try and drive off in 5th, it should stall Link to post Share on other sites
djmac 1 Posted April 8, 2014 Author Report Share Posted April 8, 2014 Thanks for the reply guys,Reaperx : im not sure if its only 2nd, i didnt want to drive it any further really, i didnt feel it in first, but maybe as i wasnt expecting it!Ill try tomorrow, Thanks Link to post Share on other sites
djmac 1 Posted April 9, 2014 Author Report Share Posted April 9, 2014 Just tested the Golf then, and there was no noise or restriction in any gear? Haven't accelerated hard, but is there any way i can check visually with out pulling the gearbox off?Cheers Link to post Share on other sites
p0u1 14 Posted April 9, 2014 Report Share Posted April 9, 2014 No, you can remove a rubber cap at the top and the cover at the bottom but you won't be able to see anything, iv had two go on me one started to slip then the other I blew up on a stupid gear change, it sounds like a gearbox fault in one gear though. Link to post Share on other sites
Lukey. 381 Posted April 9, 2014 Report Share Posted April 9, 2014 I think all the rubber bung is for is for lining up the release arm when re installing the gearbox Link to post Share on other sites
djmac 1 Posted April 10, 2014 Author Report Share Posted April 10, 2014 i may just have to take it for a test drive and have someone ready to tow at hand lol! Thanks alot for the help guys, looks like a recon Gbox and fresh clutch is in order!Cheers Link to post Share on other sites
Lukey. 381 Posted April 10, 2014 Report Share Posted April 10, 2014 What I said about the hole the bung covers up, actually quite important if you take the gearbox off, when putting the box back on you should pull the release arm forward then screw a bolt into the threaded hole so the arm is held forward, otherwise you might not get it on right and it wot operate. Link to post Share on other sites
djmac 1 Posted April 17, 2014 Author Report Share Posted April 17, 2014 Car has been running fine, only issue is, first gear sometimes slips out when setting off? There is also a noise which im guessing is the release bearing? if im static and in neutral if i press the clutch in the noise stops? Thanks guys Link to post Share on other sites
Reaperx 181 Posted April 17, 2014 Report Share Posted April 17, 2014 Sounds like the release bearing only way to find out is take it out and check it Link to post Share on other sites
