mrslippery22 2 Posted April 15, 2014 Report Share Posted April 15, 2014 My Jetta is getting hot but only if I do not have the heater on. Does anyone have any information on why this might be happening. I replaced the coolant temp sensor but it didn't seem to fix the problem. Link to post Share on other sites
Ickyketseddie 89 Posted April 15, 2014 Report Share Posted April 15, 2014 Need more information really mate. Do the fans kick in? Is it only in traffic or when you're driving too? If it's when stationary, start with the fans, if it's when driving I'd suspect the thermostat is sticking. There's somewhere to start anyway. Sent from my iPad using Tapatalk MJ Vr6 1 Link to post Share on other sites
Lukey. 381 Posted April 15, 2014 Report Share Posted April 15, 2014 Replace the thermostat and see what it's like then Link to post Share on other sites
MJ Vr6 79 Posted April 16, 2014 Report Share Posted April 16, 2014 My Jetta is getting hot but only if I do not have the heater on. Does anyone have any information on why this might be happening. I replaced the coolant temp sensor but it didn't seem to fix the problem.Please be a bit more explanitory so we can try and work the problem for you mate.Are you actually saying that the Engine temp is overheating and that when you put the heating switch on the temp drops down? Link to post Share on other sites
Lukey. 381 Posted April 16, 2014 Report Share Posted April 16, 2014 If that's the case then it sounds like your thermostat is stuck shut or your radiator is blocked, thermostats are cheap to replace but you can test them by boiling them in a pan of water and seeing if they open up. Link to post Share on other sites
mrslippery22 2 Posted April 16, 2014 Author Report Share Posted April 16, 2014 yes my fans work i have 2 10in after market fans that are set to run constantly, i have replaced the thermostat twice, ive replaced thermostat housing , leaking hoses, coolant temp valve, and it is still getting warm put yes when I turn my heat on the temp will go down and if you just keep it on then it doesn't get hot at all. Link to post Share on other sites
Lukey. 381 Posted April 17, 2014 Report Share Posted April 17, 2014 Does your bottom hose get hot? Link to post Share on other sites
mrslippery22 2 Posted April 17, 2014 Author Report Share Posted April 17, 2014 All of them get pretty Damn hotSent from my VS930 4G using Tapatalk Link to post Share on other sites
mrslippery22 2 Posted April 22, 2014 Author Report Share Posted April 22, 2014 Luke you said that to replace a thermostat is cheap. Just to let you know people in America don't know a Damn thing about vw and they want around $200 just to put a stat inSent from my VS930 4G using Tapatalk Link to post Share on other sites
CALICO 130 Posted April 22, 2014 Report Share Posted April 22, 2014 Its a simple enough job to do yourself took me about 2 hours the first time but that's because I broke the crack pipe. Link to post Share on other sites
mrslippery22 2 Posted April 22, 2014 Author Report Share Posted April 22, 2014 Yea I didn't think it was hardSent from my VS930 4G using Tapatalk Link to post Share on other sites
Lukey. 381 Posted April 22, 2014 Report Share Posted April 22, 2014 The stat itself is dead cheap and it's really easy to do it yourself just take the stat cover off on the housing under the inlet on the right hand side. You'll obviously need to replace the coolant as it will drop it all. You could do it with just a screwdriver and 5mm Allen key. Link to post Share on other sites
mrslippery22 2 Posted April 22, 2014 Author Report Share Posted April 22, 2014 Alright and yea a stat is like $20Sent from my VS930 4G using Tapatalk Link to post Share on other sites
