Was looking to change MAF, coolant temp. sensor, lambda, clean throttle body. what about a lambda cooler sensor?
Go for the MAF and Temp sensor b4 changing the Lambda.. Last resort.
Disconnect and see how it runs, wheteher the actions are still the same or not.
Mine was doing this about a month after getting the car and got worse the longer I had it . I changed loads of things to fix it and some seemed to improve it but not solve the issue . My mechanic had a nose and was baffled until he noticed that 3 of my sensors plugs where plugged in the wrong places . Been fine since then . He thinks that when my engine was refurbished by previous owner that they may have mixed them up . You had yours long ?
