grassy 4 Posted April 23, 2014 Report Share Posted April 23, 2014 just complete the engine conversion on my mk2 with a vr6 engine went to start it the other day and when i turned the key to position 3 the solenoid clicked but the motor didnt turn over.i took out the starter and bench tested it and it wasnt working properly so i stripped the whole thing down cleaned it all up ect put it back together and bench tested it and it worked properly. i put it back in the car and it turned the engine over for 5 seconds then i turned the key back and went to try it again then had nothing. it didnt turn over lightning fast so i thought maybe a flat battery.i charged up the battery and tried it again but no luck.i got jump leads and put the positive straight to the signal for the solenoid and still had no click.have i burnt out the solenoid or do i have a bad earth any help will be much appreciated! Link to post Share on other sites
grassy 4 Posted April 25, 2014 Author Report Share Posted April 25, 2014 all sorted. it was a poor earth as it still didnt work when a new starter was put in Link to post Share on other sites
