cheers, thrown 2 abs codes today
00285-035.....ABS wheel speed sensor front right
01276-016 ABS hydraulic pump signal outside tolerance
Pump shagged?
was thinking to check the connections and the green 30a fuses first
Edited by jamesw6810
Cleaned removed and refitting plugs, no change and still throwing random codes. Im thinking the ecu is dead as per 1000 more ive seen. Ive removed the ecu from the pump and its the part number that ends in an E, which turns out to be like rocking horse poop!
so part number is  3A0907379E
Any advice on further procedings as im finding it hard to find a replacement ecu.....
