paceo 22 Posted April 30, 2014 Report Share Posted April 30, 2014 ive always wondered this as its not the original engine i have and fuel economy seems ever so slightly worse than a golf, plus gave 12+ bhp at stealth racing that it should of with my mods etc (well approx from research on here)................. are there any markings on the block indicating that its a 2.9 block?? best regards Link to post Share on other sites
CALICO 130 Posted April 30, 2014 Report Share Posted April 30, 2014 If you get the engine number and ask VW they should be able to tell you Link to post Share on other sites
paceo 22 Posted April 30, 2014 Author Report Share Posted April 30, 2014 If you get the engine number and ask VW they should be able to tell you any ideas where they are stamped? i know on my rs turbo its just above the gearbox bellhousing! Link to post Share on other sites
abvsean 32 Posted April 30, 2014 Report Share Posted April 30, 2014 theres usually a sticker on the side of the rocker cover but its usually covered it dirt and cant make it out. I think theres a flat face where theres a number stamped on the side of the block above the crankshaft pulley. Link to post Share on other sites
Allymk2 18 Posted April 30, 2014 Report Share Posted April 30, 2014 The engine code is stamped on the block next to the belt tensioner.Sent from my HTC One using Tapatalk Link to post Share on other sites
CALICO 130 Posted April 30, 2014 Report Share Posted April 30, 2014 Chears guys I didn't know exactly where it was but had to be stamped into the block somewhere Link to post Share on other sites
p0u1 14 Posted May 14, 2014 Report Share Posted May 14, 2014 It's behind the fuel lines on the left side of the engine baySent from my HTC One using Tapatalk Link to post Share on other sites
Sump_slammer 23 Posted May 18, 2014 Report Share Posted May 18, 2014 Haha sorry to add to this but my engine number was stamped into the block on the gearbox side behind the rocker cover under a tone of grime. Theres a square flat surface which is at the top of the block faceing upwards. If you want a pic of where it was lemme know and ill send one. Link to post Share on other sites
