rob vr6 0 Posted May 20, 2005 Report Share Posted May 20, 2005 How easy are BBS 16" 2 piece wheels,to seperate?Do I need a special tool?(Off mk3 GTI anniversary) Link to post Share on other sites
robvr6 0 Posted May 20, 2005 Report Share Posted May 20, 2005 whoa....was trying to work out why i'd posted about bbs splits...then realised i hadn't Link to post Share on other sites
coullstar 2 Posted May 20, 2005 Report Share Posted May 20, 2005 I was looking at my wheels (same ones as you refer to) and spoke to a guy who had done this. Its not difficult to speprate and you need an 8mm spline bit to undo the bolts. Apparently its best to use and impact tool to get the initial breakout on the bolts. Be very careful as the bolts are quite rare and expensive to replace. Link to post Share on other sites
MrBen 0 Posted May 21, 2005 Report Share Posted May 21, 2005 There's a guy called S1MMA on Club GTI who has done it- might be worth talking to him. Link to post Share on other sites
rob vr6 0 Posted May 21, 2005 Author Report Share Posted May 21, 2005 I have done it now using an 8mm spline bitCheers for all your help Link to post Share on other sites
coullstar 2 Posted May 21, 2005 Report Share Posted May 21, 2005 Got any pics of the dplit wheels? Did they come apart easily as I am going to be attempting the same pretty soon. Link to post Share on other sites
Brianvr 0 Posted May 23, 2005 Report Share Posted May 23, 2005 hi also just doing the same to remove some corroded lacker and maybe polish the rims anyone got any ideas as best way to remove old lacker .also what tyres to fit.cheers.brian. Link to post Share on other sites
VR6Rich 3 Posted May 23, 2005 Report Share Posted May 23, 2005 Nitromors will do it. Link to post Share on other sites
coullstar 2 Posted May 24, 2005 Report Share Posted May 24, 2005 Anybody know what an 8mm spline bit looks like? I tried to fine one tonight to no avial. Plenty of Torx bits. Link to post Share on other sites
DundeeDub 0 Posted May 24, 2005 Report Share Posted May 24, 2005 I've got a set at home, i'll get pics on thursday Link to post Share on other sites
coullstar 2 Posted May 25, 2005 Report Share Posted May 25, 2005 Cheers, although after looking closely at the wheels its only the rims that are needing redone so I probably wont split the wheels this time. Would still be intersted for future reference. Link to post Share on other sites
Brianvr 0 Posted May 26, 2005 Report Share Posted May 26, 2005 can anyone tell me the best size tyres to fit these bbs 16" and whats a good make to buy.cheers.brian Link to post Share on other sites
coullstar 2 Posted May 27, 2005 Report Share Posted May 27, 2005 Ive got 205/40/16's (I think) Goodyear Eagle F1 GSD3's and they are brilliant. Especially in the wet. Link to post Share on other sites
FishWick 21 Posted May 27, 2005 Report Share Posted May 27, 2005 You can use a normal socket as what you get in Halfords professional sets to undo the bolts. They're not rare or expensive, well, I suppose Link to post Share on other sites
Brianvr 0 Posted May 29, 2005 Report Share Posted May 29, 2005 hi so i take it that 205/40/16 tyres are best to fit these wheels on a golf mk3 vr6 . Link to post Share on other sites
MrBen 0 Posted May 29, 2005 Report Share Posted May 29, 2005 The standard size as fitted to Mk3 Anniversarys is 215/40/16, so is probably the best. People have also been known to run 205/45/16 which isn't far different and can be a little cheaper. I run 205/40/16 on mine, and find the ride a bit harsh as they are lower profile than the 215/40's I had before. Link to post Share on other sites
Junior VR6 0 Posted June 3, 2005 Report Share Posted June 3, 2005 I will be very happy when i find wheels like yours! He in Brazil is very difficult and expensive a BBS set. We heve a several types and factures, but BBS is simply the best. So, i must have have fun with my 15" sets.15x6,5 - for track-dayshttp://www.santafuria.trix.net/hcc/fotosforum/dsc00106.jpg15x6 - for streethttp://www.santafuria.trix.net/hcc/fotosforum/alturasuspensao_01.jpg Link to post Share on other sites
Devilfish 0 Posted June 3, 2005 Report Share Posted June 3, 2005 threadlock the bolts when you put them back and torque in the correct order ! Link to post Share on other sites
jte 0 Posted June 6, 2005 Report Share Posted June 6, 2005 Does anyone know the correct torque for doing these bolts back up? Link to post Share on other sites
Brianvr 0 Posted June 7, 2005 Report Share Posted June 7, 2005 can someone tell me why there is a need to use silican sealer before reasembling,and do you just smear it around bolt hole surface area ,also would like to know torque settings.looking to fit 205/45/16scheers. brian Link to post Share on other sites
purple highline monster 0 Posted June 7, 2005 Report Share Posted June 7, 2005 the silicon just re-seals the rim stopping any air leaks! the stuff bbs use is nasty! good waterproof silicon is ideal, dont know about the torque settings but its tight! dont snap em though or you will be stating again after a bit of drilling! there was a guy who sold rallyes who had all the bolts and rims he would know but i cant remember his name though! i am sure awesome or dubsport would know? Link to post Share on other sites
purple highline monster 0 Posted June 7, 2005 Report Share Posted June 7, 2005 oh sealant needs to go all the way around the rim too!! Link to post Share on other sites
Brianvr 0 Posted June 7, 2005 Report Share Posted June 7, 2005 my wheels are 2 piece and cant see were air would leak from ,as wiyh center of wheel out the tyers are still on and full of air Link to post Share on other sites
purple highline monster 0 Posted June 7, 2005 Report Share Posted June 7, 2005 appologys thought you had split the the two parts to change the rims Link to post Share on other sites
jte 0 Posted June 9, 2005 Report Share Posted June 9, 2005 The outer rim that holds the tyre and air is one piece, the other piece is just a bolt on front.I discovered this when i took one apart last night!I emailed BBS to find the torque settings and got a reply from 'Wendig' - "we do not publish torque settings as it is not allowed to split the rims, this will lose your garanty and your safety"Obviously they have to cover their backs in this situation, so i understand them not wanting to give out torque settings, but is it actually dangerous to use the wheels if they have been split and put back together using appropriate torque settings? If the torque was checked before undoing some bolts, would that be a safe torque to use on reassembly? Link to post Share on other sites
