Ive suspected something is up with my corrado for a little while and I have changed numerous parts to cure the niggle. The problem is that while the idle is steady its not silky smooth as it was a few months back, ive also noticed a slight pop when reved to just over 2000 rpm from the exhaust. I dont recall this before.
I have had the diagnostics checked with no faults, ive had the coil pack, Ht leads, cam sensor, engine speed sensor, spark plugs, head gasket and water pump changed in the several months leading up to this.
Has anyone had a similar problem?
Cheers.
Cheers fellas, I am probably nit picking but I dont remember it being like it when I had it for the first few months. Maybe it was just the excitement of owning it.
I have also noticed a slight hesitation on the throttle and it doesnt feel as torquey at low revs as it did a few months back.
Cheers fellas' date=' I am probably nit picking but I dont remember it being like it when I had it for the first few months. Maybe it was just the excitement of owning it.
yeah, i'd say clean the TB and ISV with carb cleaner...should hopefully sort it out.
yep, poor idle is usually the ISV.
don't buy a new one, just give the current one a good clean with carb cleaner (sometimes takes a few cleans to get it perfect)
its a silver cylindrical thing, next to the black plastic virbation damper.
