tonygti 22 Posted May 11, 2014 Report Share Posted May 11, 2014 Hi there I'm rebuilding the bottom end on my engine and noticed the oil pump shaft that the top timing chain sprocket connects to on the bottom end has play in and out ?is this normal? I have put a new oil pump and rod and pick up pipe. Does this mean the shaft is worn or is this normal thanks Link to post Share on other sites
