al_mooring 102 Posted May 18, 2014 Report Share Posted May 18, 2014 (edited) Hi everyone! I'm new here so thought I would share my newest project with you all!Started out life as a grey 1.6 and the previous owner has built it into a red big bumper gti look a like.So fast forward a few years and here is how she sitsThe car as I bought it came with:Us spec tail lights Clear rear window kW v1 coiloversAnti roll barsSmoothed front and rear bumpersAudi s2 front brakes with braided hosesTransporter t5 banded steelsLightweight battery in the bootBut more to the point this has hardly any rust, only major problem is both front jacking points have rusted through but that will be easily sorted.So my plans for this Are:Shaved engine bayPolybush everything Forged and rebuilt 2.8 vr6Precision 6262 turbo Sidewinder manifold O2m swap Stripped interiorBuckets Cage Motorsport shifter Respray (same colour)15" gotti g1001 wheelsYesterday I went round and helped pull the g60 engine out ready to get it recovered back to my house So will hopefully have it back at my house Monday (fingers crossed) where I can really get stuck into thingsHere's the vr6 engine conversion I have bought, engine has done 90k but will be getting stripped to the bare block and head and rebuilt And my gotti g1001 wheels. These were made January 1990 and never even seen a car hub or a tyre they are brand new and diamond cut Need wider lips front and rear so these will be getting stripped down soonthanks for looking [THUMBS UP SIGN][THUMBS UP SIGN] Edited July 5, 2015 by al_mooring D11PS 1 Link to post Share on other sites
al_mooring 102 Posted May 18, 2014 Author Report Share Posted May 18, 2014 Just spent tonight searching for a decent 02m box with all the trimmings and going to pick one up later this week! Going to get a paddle clutch (looking at clutch master fx850's) and a LSD Link to post Share on other sites
edlucasevw 0 Posted May 19, 2014 Report Share Posted May 19, 2014 Very Sexy, Keep us posted mate! What is your gearbox set-up exactly? Can you go into a bit more detail? Link to post Share on other sites
Surreyvr6 199 Posted May 19, 2014 Report Share Posted May 19, 2014 Looks like another great build thread to enjoy seeing progress love those gotti's!! Where these for sale not so long ago?Sent from your mums iPhone using Tapatalk Link to post Share on other sites
al_mooring 102 Posted May 19, 2014 Author Report Share Posted May 19, 2014 Very Sexy, Keep us posted mate! What is your gearbox set-up exactly? Can you go into a bit more detail?Thanks and you mean my 02m gearbox setup? I'll be using a mk4 golf 4motion gearbox then put a transfer box blank on and use the 02m shafts to modify half and half with mk2/mk3 out cv's then you have to weld the gearbox mount in a different place and use a front and gearbox mount from dutchbuild unless you want to make your own (quite easy) and then fitting a clutchmaster fx850 clutch and quaife LSD.You then have to use the 02a master clutch cylinder and make an adapter to go from 6mm to 8mm pipe to the 02m slave cylinder have a look here http://forums.vwvortex.com/showthread.php?2633108-02m-o2m-6-speed-into-mk3-12v-VR6-(56k-very-very-beware)Looks like another great build thread to enjoy seeing progress love those gotti's!! Where these for sale not so long ago?Sent from your mums iPhone using TapatalkThanks! And Yes my friend Jamie (wheelgeek) was selling them so swapped my 18" Breytons for those and cash. Link to post Share on other sites
Surreyvr6 199 Posted May 19, 2014 Report Share Posted May 19, 2014 Ah thought I saw them while I was after some new wheelsSent from your mums iPhone using Tapatalk Link to post Share on other sites
al_mooring 102 Posted May 19, 2014 Author Report Share Posted May 19, 2014 Few pictures of the mk2 been brought back to its new home, need to shuffle a few cars about and then will have the ideal spot for the rebuild Surreyvr6 1 Link to post Share on other sites
edlucasevw 0 Posted May 19, 2014 Report Share Posted May 19, 2014 Thankyou for the info I shall look into this further Link to post Share on other sites
al_mooring 102 Posted May 20, 2014 Author Report Share Posted May 20, 2014 Thankyou for the info I shall look into this further You also need 02m starter motor, flywheel and 24v clutch but not a problem Link to post Share on other sites
Daverse 175 Posted May 20, 2014 Report Share Posted May 20, 2014 And thermostat housing:)Welcome dudeSent from my GT-I9300 using Tapatalk Link to post Share on other sites
al_mooring 102 Posted May 21, 2014 Author Report Share Posted May 21, 2014 So after removing the rest of the wiring loom, hydro clutch and brake master cylinder I decided to remove some old metal in place for nice shiny bits that Matt gave me with the car, shame no one is going to see them as I am smoothing over the top with sheet metal but I like to do things right and do them once Using a grinder wire knot wheel to remove sealer it's the easiest way I've found and then drilling out the spot welds. Going to seam weld everything so no one seam sealant and no filler needed (hopefully) Link to post Share on other sites
al_mooring 102 Posted May 23, 2014 Author Report Share Posted May 23, 2014 Yesterday I went to see lowvr off the forum to pick up an 02m box, c2 mount and gear shifter along with a Modified mk3 subframe and had a good chinwag and then I had to jump on a flocked dash for £30 so went and picked that up No photos of the gearbox but I also order a 2wd conversion blanking plate from holland Then today I have replaced the chassis leg panel on the drivers side and welded up the large hole above it on the inner wingTook the wing off so I could get underneath to weld the panel and was pleased to see no rustJust need to carry on smoothing the bay!Oh and this got dropped off today as well and looks decent from the quick inspection I gave it lol c00k 1 Link to post Share on other sites
al_mooring 102 Posted May 26, 2014 Author Report Share Posted May 26, 2014 Started stripping down the engine and gearbox yesterday. Everything looks to be in great shape, which makes it even more of a shame to split the engine down to fit new pistons and rods but hey ho! Waiting for a proper engine stand to be delivered so I don't have to work on a trolley anymore (sketchy AF) lol daveyboy and D11PS 2 Link to post Share on other sites
al_mooring 102 Posted May 30, 2014 Author Report Share Posted May 30, 2014 Quick picture of how the engine bay is coming along...... Until I ran out of mig wire but I have stocked back up and shall be attacking it again over the weekend Link to post Share on other sites
al_mooring 102 Posted June 11, 2014 Author Report Share Posted June 11, 2014 Got one side in primer now moving along to the fire wall and other side. Here are a few pictures of the progressAlso bought some drop in 8:1 wossner pistons and genuine rod bearings daveyboy and Surreyvr6 2 Link to post Share on other sites
al_mooring 102 Posted June 12, 2014 Author Report Share Posted June 12, 2014 Just placed my order to migfab to have a SRI made up with the throttle body on the opposite side so the intercooler pipework is right ready for the sidewinder manifold I'll be having made. D11PS and daveyboy 2 Link to post Share on other sites
al_mooring 102 Posted June 20, 2014 Author Report Share Posted June 20, 2014 So bit of a late update but had a few problems to deal with the car. Went to lay paint down and the cellulose reacted with the acrylic primer so I had to flat it all back and refill some areas but overall I'm happier so glad I did it. After seeing jason pattons' mk2 jetta I've loved the whole stone chipped engine bay look and it's really durable so perfect for what I wanted.And here is mine so far,Finished wire wheeling and stone chipping the inner arch and the chassis leg so that side is done and it drys a lot more "matt" then in that picture as that is when I just sprayed it. The engine is going to be the centre piece but still deciding on a few things. Bought some forged rods as well just they willing be delivered with my inlet manifold I have also been stripping the engine and subframes ready to swap everything over to the mk3 subframe so wire wheeled the wishbones and etched primed themOff to Cumbria vag this weekend so no progress for a while again.Thanks for looking Link to post Share on other sites
al_mooring 102 Posted August 18, 2014 Author Report Share Posted August 18, 2014 Little bit more progress got the new battery tray panel in on the opposite side, smoothed it and got it in primer after de-seaming everything.... Just a little more welding needed on a few holes and I should have it done.And then got the vr6 bolted onto my new engine stand but had to slightly alter the stand to get it to bolt onto the vr6 rear mount Also bought a solid mk2 front engine mount so I don't need to buy another crossmember Link to post Share on other sites
DanChave 98 Posted August 24, 2014 Report Share Posted August 24, 2014 Rad project, I like the stonechipped bay idea, something a bit different Link to post Share on other sites
jaks14 174 Posted August 25, 2014 Report Share Posted August 25, 2014 Really liking the bay.. I think I would have colour coded mine if I was to pull the lump out.. but I do lik3 the stone chip look, great idea and protects the body in a massive way.. plus you can just wash it down and be good as new.. Keep up the good work mate Link to post Share on other sites
al_mooring 102 Posted August 26, 2014 Author Report Share Posted August 26, 2014 Thanks guys! It is marmite but that picture above really does make the stonechip out to look shiny and very textured when in fact it's quite matt and smooth! Lol on nights at the moment but going to pull my finger out for the rest of the week and hopefully have it done Link to post Share on other sites
al_mooring 102 Posted September 26, 2014 Author Report Share Posted September 26, 2014 Engine bay is now painted and I have now stripped the vr6 down to its bare block ready for a full rebuild with fresh bearings, arp hardware everywhere, forged rods and pistons and a lick of paint.Engine looks in great shape and the previous owner had fitted a baffled sump and new timing chains/guides but I'll be re-newing them just for piece of mind.Then tonight I went and bought some more wheels for it, this time some banded 9j g60 steels Just need to go back and pick up the centre caps as I forgot to take them! Lol daveyboy 1 Link to post Share on other sites
al_mooring 102 Posted November 11, 2014 Author Report Share Posted November 11, 2014 Well I have now bought everything I need to build the block up and also my turbo came yesterday it's a monster! And I'm also painting all the suspension/subframes/crossmembers ready to fit to the car Russvrt 1 Link to post Share on other sites
daveyboy 897 Posted November 11, 2014 Report Share Posted November 11, 2014 Is that off a volvo truck lol Link to post Share on other sites
dowanm1 0 Posted November 11, 2014 Report Share Posted November 11, 2014 That is rather large, will be quite fast then........ Link to post Share on other sites
