Sump_slammer 23 Posted June 1, 2014 Report Share Posted June 1, 2014 So I'm in the process of doing the chains, and whilst the engine is out I'm swopping the cams and fitting a billet ally flywheel ready for supercharging. I think power wise it will make around the 270/280 mark. I don't like the idea of fitting a F1 style paddle clutch which will make it horrible for daily driving but don't want any chance of slipping. What clutch do you think will be right for me? Link to post Share on other sites
Lukey. 381 Posted June 1, 2014 Report Share Posted June 1, 2014 Pretty sure the stock clutch can hold 300nm Link to post Share on other sites
Sump_slammer 23 Posted June 1, 2014 Author Report Share Posted June 1, 2014 Do you think it would be worth upgrading to a organic clutch? Or if I stay standard what makes are good? Link to post Share on other sites
Sump_slammer 23 Posted June 2, 2014 Author Report Share Posted June 2, 2014 Standard clutch makes? Link to post Share on other sites
Lukey. 381 Posted June 2, 2014 Report Share Posted June 2, 2014 not sure on organic clutch, havent looked into it myself, theyre supposed to be stronger but feel like stock arent they. Standard choices are VW obviously, sachs, luk, valeo. I think VW use LUK mostly in their gen kits. Link to post Share on other sites
craggsy 91 Posted June 2, 2014 Report Share Posted June 2, 2014 For that power stock will be fine unless you like launching it off every set of lights or go drag racing lots VR6Pete 1 Link to post Share on other sites
Sump_slammer 23 Posted June 2, 2014 Author Report Share Posted June 2, 2014 So luk sounds the best bet. Cheers ill have a look Link to post Share on other sites
VR6Pete 1,455 Posted June 6, 2014 Report Share Posted June 6, 2014 Got valeo on mine as recommended by stealth racing over luk or saschClub Chairman Link to post Share on other sites
