cpfcvr6 6 Posted June 2, 2014 Report Share Posted June 2, 2014 (edited) sorry for the questions chaps, i don't come on here a lot. but the information i get is great! (as you know my vr6 headgasket is going) i will be super-charging in the future - stage 2! i know from vince @ stelath racing that its ok to run a standard headgasket on my stage 2 supercharger when eventually fitted. but for peace of mind i want to lower the compression, is it just a thicker metal gasket over the standard gasket? guess it will be ok to run it N/A for a while?? also where is best place to buy one? kind regards Edited June 2, 2014 by cpfcvr6 Link to post Share on other sites
CALICO 130 Posted June 2, 2014 Report Share Posted June 2, 2014 yes you can run n/a with spacer plate. Ebay.de is the cheapest place to buy one once you have decided how thick you need it to be. Link to post Share on other sites
cpfcvr6 6 Posted June 3, 2014 Author Report Share Posted June 3, 2014 yes you can run n/a with spacer plate. Ebay.de is the cheapest place to buy one once you have decided how thick you need it to be. stage 2 supercharger running 10 psi, i have no idea what one i need?? does this just fit with the normal headgasket? Link to post Share on other sites
Lukey. 381 Posted June 3, 2014 Report Share Posted June 3, 2014 To run a spacer you need the multi layered metal head gasket which you then split and sandwich the plate between the two outers MJ Vr6 and cpfcvr6 2 Link to post Share on other sites
MJ Vr6 79 Posted June 3, 2014 Report Share Posted June 3, 2014 stage 2 supercharger running 10 psi, i have no idea what one i need?? does this just fit with the normal headgasket?10psi is the so called 'Stage3' and as Lukey says - multi layered metal head gasket which you then split and sandwich. cpfcvr6 1 Link to post Share on other sites
cpfcvr6 6 Posted June 3, 2014 Author Report Share Posted June 3, 2014 (edited) To run a spacer you need the multi layered metal head gasket which you then split and sandwich the plate between the two outers thanks lukey, i thought initially the reinz headgasket could be split!! whats the best multi layered headgasket that people use?? do not want cheap crap!! any links? Edited June 3, 2014 by cpfcvr6 Link to post Share on other sites
CALICO 130 Posted June 3, 2014 Report Share Posted June 3, 2014 VW headgasket I would imagine 2mm would be fine but I don't know enough about it tbh I had one think it was 2.5mm but I was going to run a turbo. cpfcvr6 1 Link to post Share on other sites
cpfcvr6 6 Posted June 3, 2014 Author Report Share Posted June 3, 2014 VW headgasket I would imagine 2mm would be fine but I don't know enough about it tbh I had one think it was 2.5mm but I was going to run a turbo. vince at stealth said its up to me, could possibly get away with it! but for peace of mind as its got to come off i may aswell do it! where do i get a proper good metal headgasket and spacer from?? Link to post Share on other sites
CALICO 130 Posted June 4, 2014 Report Share Posted June 4, 2014 (edited) Head gasket from TPS or Vw spacer plate from ebay.de for cheapness Edited June 4, 2014 by CALICO Link to post Share on other sites
cpfcvr6 6 Posted June 4, 2014 Author Report Share Posted June 4, 2014 (edited) Head gasket from TPS or Vw spacer plate from ebay.de for cheapness will the tps one just be a standard reinz gasket that cant be split?? any links on ebay will be good! Edited June 4, 2014 by cpfcvr6 Link to post Share on other sites
CALICO 130 Posted June 4, 2014 Report Share Posted June 4, 2014 TPS is the trade version of VW main dealer there is one in Crawley and one in Burgess Hill Link to post Share on other sites
cpfcvr6 6 Posted June 4, 2014 Author Report Share Posted June 4, 2014 TPS is the trade version of VW main dealer there is one in Crawley and one in Burgess Hill i know dude, but wont be just be a standard gasket that cant be split? Link to post Share on other sites
CALICO 130 Posted June 4, 2014 Report Share Posted June 4, 2014 Don't think so think the vw one is 3 part with rivets. cpfcvr6 1 Link to post Share on other sites
cpfcvr6 6 Posted June 4, 2014 Author Report Share Posted June 4, 2014 Don't think so think the vw one is 3 part with rivets. cool, then obviously i need to find a decompression plate from somewhere, would guess stealth sell them! Link to post Share on other sites
CALICO 130 Posted June 4, 2014 Report Share Posted June 4, 2014 Depends how much they are think I bought mine from storm developments but here's a link to one on ebay.dehttp://www.ebay.de/itm/vw-vr6-head-spacer-9-1-c2-style-Turbo-/181410276497?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a3ce52491 cpfcvr6 1 Link to post Share on other sites
VR6Pete 1,455 Posted June 6, 2014 Report Share Posted June 6, 2014 I ran my low compression vr6 for months but wrote it off before boosting it! It was running a healthy 221bhp and was amazing to drive. Club Chairman Link to post Share on other sites
daveyboy 897 Posted June 6, 2014 Report Share Posted June 6, 2014 Hmm so you get a bit more power by lowering the compression and running N.A? Sent from my SM-G900F using Tapatalk Link to post Share on other sites
VR6Pete 1,455 Posted June 6, 2014 Report Share Posted June 6, 2014 Hmm so you get a bit more power by lowering the compression and running N.A? Sent from my SM-G900F using TapatalkYou shouldn't usually, I had a fresh engine build which probably helped built at stealth, also had wossner pistons for good measure lol. Theory of lowering compression still remains. Club Chairman Link to post Share on other sites
