Is remap needed after performance cams fitted
  • 3 weeks later...
Map it to the cams. What else will you do that will mess with the afr? Cams open and close the valves witch will create a fuel problem. If you add a flywheel or pulleys the ecu will adapt itself to it. Unless you port the head etc etc just get a cam tune and call it a day.
Hi, i mapped after 263's, went from 190-196HP, i then went back to vince @ stealth after the schrick install and he did a deal as it was still a N/A tune, got a bit off so always worth asking!
Vince also said that the VR was running lean with the Schrick, as you know this can kill engines so best to get a tune.
good luck
s
Fit a schrick manifold.
Im running schrick 268's in mine with no map. The additional air is metered via the MAF which sorts out the fuelling.
If youre planning on sticking a schrick manifold on it then the combination of the two plus the other supporting mods such as filter, 6 branch decat back system etc would be helped by a map adjustment.
But personally i can think of better ways of spending £500 on the car for a negligible gain.
