robwillz91 0 Posted June 15, 2014 Report Share Posted June 15, 2014 has anyone know or made a engine mount using a hockey puck? if you have or a guide please show me. thanks in advance. Link to post Share on other sites
daveyboy 897 Posted June 15, 2014 Report Share Posted June 15, 2014 Apparently you just drill the centre of the puck and put it in place of the standard rubber and use a longer bolt. Sent from my SM-G900F using Tapatalk Link to post Share on other sites
Russvrt 85 Posted June 15, 2014 Report Share Posted June 15, 2014 I found a guide on this a while back,,( think it was on club gti?) you drill out 3 hockey pucks with a 20mm hole then replace the rubber section with these ,simple as that ,,I will be doing this to my front and rear mounts soon so will do a guide with pics as I go .. Surreyvr6 1 Link to post Share on other sites
daveyboy 897 Posted June 15, 2014 Report Share Posted June 15, 2014 I think I'll be doing mine when I do my engine swap Sent from my SM-G900F using Tapatalk Link to post Share on other sites
dom.joy 87 Posted June 17, 2014 Report Share Posted June 17, 2014 Just keep an eye on driveshaft and bonnet clearance Link to post Share on other sites
bennyk 1,238 Posted June 17, 2014 Report Share Posted June 17, 2014 Have had to get a bottom pulley machined down on mine as it catches on the chassis leg when turning left and cut a lump out of my bonnet to clear my schrick! Sent from my iPhone using Tapatalk Link to post Share on other sites
mattvr6 133 Posted June 17, 2014 Report Share Posted June 17, 2014 I did I this with no problems at all Sent from my iPhone using Tapatalk Link to post Share on other sites
vr6kelvin 5 Posted June 18, 2014 Report Share Posted June 18, 2014 You guys used it has a mount or a engine lift kit? Link to post Share on other sites
mattvr6 133 Posted June 18, 2014 Report Share Posted June 18, 2014 Lift kit worked a treatSent from my iPhone using Tapatalk Link to post Share on other sites
dom.joy 87 Posted June 18, 2014 Report Share Posted June 18, 2014 I looked at this but didnt think I had the driveshaft clearance Link to post Share on other sites
daveyboy 897 Posted June 18, 2014 Report Share Posted June 18, 2014 Do you think I'd get the sump up a little if I just done the front mount with a puck?Sent from my SM-G900F using Tapatalk Link to post Share on other sites
MrCypherr 1 Posted June 18, 2014 Report Share Posted June 18, 2014 I did it on mine. First I only put 1 puck on the rear mounts and the sump was basically flush with the subframe. Then I added one to the front and now it just sits perfectly. No problems with the bonnet. daveyboy 1 Link to post Share on other sites
Surreyvr6 199 Posted June 18, 2014 Report Share Posted June 18, 2014 Is there any particular puck to get? Sorry if it's a silly question but ain't got a clue if they differ in hardness, size etcSent from your mums iPhone using Tapatalk Link to post Share on other sites
leon263 31 Posted June 18, 2014 Report Share Posted June 18, 2014 They are all a standard size and hardness ........... 3 inches in diameter and 1 inch thick and you'll get one on e-bay for £1.50 Surreyvr6 1 Link to post Share on other sites
MrCypherr 1 Posted June 19, 2014 Report Share Posted June 19, 2014 Any sports store. Sent from my iPhone using Tapatalk Link to post Share on other sites
J4Y VR 36 Posted June 19, 2014 Report Share Posted June 19, 2014 Any sports store. Sent from my iPhone using TapatalkTry ebay that's where I got mine from. Link to post Share on other sites
Surreyvr6 199 Posted June 19, 2014 Report Share Posted June 19, 2014 Cheers seen them on ebay, was just curious as to if they differ in strengths, hardness etc as no sweet f a about hockey and pucks lol Sent from your mums iPhone using Tapatalk Link to post Share on other sites
daveyboy 897 Posted June 20, 2014 Report Share Posted June 20, 2014 I've just bought 3 for £6.49 Inc p & off ebaySent from my SM-G900F using Tapatalk Surreyvr6 1 Link to post Share on other sites
