MrCypherr 1 Posted June 21, 2014 Report Share Posted June 21, 2014 Now I know this topic might come up alot and that I should just search. Oh well. LolAnywAys, i got my chains done (Upper and lowers) and got the car back today. I went to pick it up, turned it on and it sounded like a subie. No CEL and it idles fine. Couple of buddies looked at it and its not plugs or coilpack. I havent check the spark plugs but they said it could be the timing. Im thinking that also. A puff of black smoke came out when i was shifting gears on the highway (all of them) I had my brother behind me and he told me. The car drives fine it just doesnt sound right or feel right you know? Anyone know what this could be? im bringing it back tomorrow to the shop but would just let to get an idea.Thanks! Sent from my iPhone using Tapatalk Link to post Share on other sites
J4Y VR 36 Posted June 21, 2014 Report Share Posted June 21, 2014 Check the timing on the cams it might be out by 1 tooth. When I bought my Vr the seller said it had cams fitted to it which was bullshit, I checked everything turned out to be cam timing. This is after I adjusted the cam back. http://youtu.be/sEFjBJWS2hw Sent from my iPhone using Tapatalk MJ Vr6 1 Link to post Share on other sites
MrCypherr 1 Posted June 21, 2014 Author Report Share Posted June 21, 2014 (edited) Im going back to the shop tomorrow to tell them and see if they can fix it asap. Not sure how bad it is to drive like this. Right when i turned it on I knew the timing was off. I was just hoping I was wrong. Sent from my iPhone using Tapatalk Edited June 21, 2014 by MrCypherr Link to post Share on other sites
J4Y VR 36 Posted June 21, 2014 Report Share Posted June 21, 2014 You can adjust the timing in place if the cam timing is out. Take off rocker cover off set bottom pulley to tdc and see if the two slots are level Link to post Share on other sites
MrCypherr 1 Posted June 21, 2014 Author Report Share Posted June 21, 2014 If they are not leveled how can i go about adjusting it?Sent from my iPhone using Tapatalk Link to post Share on other sites
MJ Vr6 79 Posted June 22, 2014 Report Share Posted June 22, 2014 (edited) I'd say it's more than one tooth out, if it's just the one tooth car wouldn't miss fire as such nor sound like Jap, So you've checked plugs and coil pack, have you actually looked at the HT leads at all? Just double check them as we'll, as I had one that was arching, number 6, caused same problem. Edited June 22, 2014 by MJ Vr6 Link to post Share on other sites
Zdive65 0 Posted June 22, 2014 Report Share Posted June 22, 2014 I have similar problem, I verified TDC, still rough idle and stalks out Link to post Share on other sites
MrCypherr 1 Posted June 22, 2014 Author Report Share Posted June 22, 2014 The idle and everything is steady. But there is loss of power after 3k rpm. I'm going to check the main engine connector terminals, and the HT leads. Link to post Share on other sites
Zdive65 0 Posted June 22, 2014 Report Share Posted June 22, 2014 VR6 , 630cc, GT35R, 4" MAF, new 1 MM over valve head, new wires, new coil, new plugs, new tune from C2 motorsports, injectors cleaned and matched, cams set to top dead cent and verified. wont idle, stalls, sounds like running on 5 cylinders..... Link to post Share on other sites
MJ Vr6 79 Posted June 24, 2014 Report Share Posted June 24, 2014 The idle and everything is steady. But there is loss of power after 3k rpm. I'm going to check the main engine connector terminals, and the HT leads.If Idle is steady, the car deffo aint missing then, you'd hear it as soon as you start.What HT leads are using mate? Link to post Share on other sites
Antihero1981 8 Posted June 25, 2014 Report Share Posted June 25, 2014 if you have paid to have it done then i would take it back , you start playing with it and they might not fix it ... you checked spark plug leads? they are easily broken /damaged Link to post Share on other sites
