djmac 1 Posted June 23, 2014 Report Share Posted June 23, 2014 Hi all, a while back i rolled my arches to fit my modern lines, which meant i had to remove the trip including the rivets holding the arches, i used a mastic to hold them on but it hasn't lasted, can anyone advise anything to use? Cheers Dan Link to post Share on other sites
Big J 283 Posted June 23, 2014 Report Share Posted June 23, 2014 A good body shop grade seam sealer should hold them but make sure the arch and the trim are well degreased first, either brake cleaner or alcohol wipe of some sort should do it. Try and stick them as close to the edge as you can to avoid trapping moisture and shite down there Link to post Share on other sites
sep 68 Posted June 24, 2014 Report Share Posted June 24, 2014 windscreen sealer is the best. sikka flex of tiger seal Link to post Share on other sites
