Bealieboy 1,625 Posted June 29, 2014 Report Share Posted June 29, 2014 Hi fellas, how quick should the fan cut in after a 20 min drive, motorway 65-70mph then a bit of traffic? Today isn't overly warm, just a bit suprised the fan came on so soon, although I do appreciate the vr6 likes to run hot. Temp gauge and oil temp was fine. Any comments welcome. CheersSent from my iPhone using Tapatalk Link to post Share on other sites
Rick's RadoVR6 27 Posted June 29, 2014 Report Share Posted June 29, 2014 That's pretty normal mate nothing to worry about really! Link to post Share on other sites
bennyk 1,238 Posted June 29, 2014 Report Share Posted June 29, 2014 Hi fellas, how quick should the fan cut in after a 20 min drive, motorway 65-70mph then a bit of traffic? Today isn't overly warm, just a bit suprised the fan came on so soon, although I do appreciate the vr6 likes to run hot. Temp gauge and oil temp was fine. Any comments welcome. CheersSent from my iPhone using TapatalkYou didn't have your air con on did you? Link to post Share on other sites
Bealieboy 1,625 Posted June 29, 2014 Author Report Share Posted June 29, 2014 No mate, it doesn't work. A120 plus a bit round stortford and when I pulled up to yours the fan was running. Same when I got home. Sent from my iPhone using Tapatalk Link to post Share on other sites
Bealieboy 1,625 Posted June 29, 2014 Author Report Share Posted June 29, 2014 That's pretty normal mate nothing to worry about really!thanks, just struck me that it didn't get that warm. Perhaps I'll have a drive round with the diagnostic thing plugged in and see what temps are showingSent from my iPhone using Tapatalk Link to post Share on other sites
bennyk 1,238 Posted June 29, 2014 Report Share Posted June 29, 2014 I wouldn't worry to much if all your gauges are reading ok, just keep an eye on your water level. I'm sure mine runs on when I pull up sometimes. Link to post Share on other sites
Rick's RadoVR6 27 Posted June 29, 2014 Report Share Posted June 29, 2014 My mk3 did the same! I have an uprated rad in my corrado from psi which keeps the temp around 75 to 85 and cools the engine for two mins once ignition is off Link to post Share on other sites
Bealieboy 1,625 Posted June 29, 2014 Author Report Share Posted June 29, 2014 I check water and oil most times before I drive it, so all is well under the bonnet, gauges read fine too. I've notice that the expansion tank when cold is a little low to the max, but when running it's a little above. Perhaps I'll stick some water wetter in. Sent from my iPhone using Tapatalk Link to post Share on other sites
Lukey. 381 Posted June 29, 2014 Report Share Posted June 29, 2014 when cold the coolant should be up to the min level Link to post Share on other sites
Bealieboy 1,625 Posted June 29, 2014 Author Report Share Posted June 29, 2014 when cold the coolant should be up to the min levelThanks lukey, I didn't expect that comment. I'll syphon a little out. Sent from my iPhone using Tapatalk Link to post Share on other sites
sep 68 Posted June 30, 2014 Report Share Posted June 30, 2014 Mine runs like this miles better since coolant at minimum Bealieboy 1 Link to post Share on other sites
Bealieboy 1,625 Posted June 30, 2014 Author Report Share Posted June 30, 2014 Cheers sep, another great commentSent from my iPhone using Tapatalk Link to post Share on other sites
Vince12v 20 Posted July 7, 2014 Report Share Posted July 7, 2014 I just got a 70* stat for mine, hoping it keeps the temps down a bit Link to post Share on other sites
