Vr6 running hot?
Hi fellas, how quick should the fan cut in after a 20 min drive, motorway 65-70mph then a bit of traffic? Today isn't overly warm, just a bit suprised the fan came on so soon, although I do appreciate the vr6 likes to run hot. Temp gauge and oil temp was fine. Any comments welcome. Cheers
You didn't have your air con on did you? ;)
I check water and oil most times before I drive it, so all is well under the bonnet, gauges read fine too. I've notice that the expansion tank when cold is a little low to the max, but when running it's a little above. Perhaps I'll stick some water wetter in.
