Hi All,
Thought I would make a build for this car as I consider it a car that I will probably keep forever. Ill start with a few pictures of previous cars..
My 2.0 8v Jetta.. 2.0 bottom end, 1.8 p+p cylinder head, 4-2-1 manifold, 900 carbs, 268 newman camshaft. was very good fun for my first attempt at modifying a car.
Mk1 mx5..
Mk3 Vr6/Mk2 vr6 build..
My Current car..
I bought the car from a really good friend about a week after finishing my own mk2 vr6 project car, its a 1991 bright blue metallic OBD1 2.8 vr6, G60 arches, Electric windows, momo team 280 steering wheel, coil overs, full polyurethane bush kit, hydro clutch, corrado front crossmember and fan set up, solid seat front engine mount, amongst a few other cool bits..
the day I bought the car..
AF1F3895-7791-4E5B-AC10-F3CE73CC2A75_zps
Decided for piece of mind I would do the head gasket as it was weeping slightly from the pulley side, ended up having a skim, pressure test, clean up, new stem seals and new valve guides. Wish id have spent longer trying to get a mk4 metal head gasket and stuck some 264 cams in there that i am now saving for when it was all apart but oh well can come apart again. bought other parts that needed doing like chain guides and chain tensioner bolt and all back together and running sweet again.
CFE8788F-0F77-4073-BD86-4FF97FEDB59F_zps
DB4E5D2F-ED1E-4597-99F0-40B91AF3FBCF_zps
Then decided the air filter was haggard and I needed a new one, didn't like the old one hanging off the MAF so decided to make ain intake pipe and mod a 1.8T AIT into it and extend my wiring.
3D842CBF-E24F-402F-AECA-783F22B94BEB_zps
595FC84C-3975-45FC-9244-4C8167097A6F_zps
2115F2D0-1031-49AB-BE63-8D0839E1893F_zps
Shortly after I found some rust that needed attending to above the rubber fuel filler guard, seems to trap loads of rubbish behind it, cut it out and welded a small new plate in..
52D105E5-0911-4810-9CCB-F371DBB978DF_zps
492A484A-51D6-414B-98E2-C7EB6A4E9ADB_zps
BD8E37A7-68E9-4217-B465-5735A5649F22_zps
seam sealered and undersealed up and all was good again.
Then decided I needed some new wheels as the bbs reps that were on it were pitted, curbed and nasty..bought some 16x8 et30 rota D154s and stuck them on with toyo rubber and some 10mm and 20mm hubcentric spacers and longer bolts to suit
C05B5E0A-F182-4313-BA25-9041DE9D65F7_zps
D3ABA29D-D7E3-4979-BDD7-79A17C310034_zps
engine bay as it stands.. (plastics are off to get painted gloss black)
9AF90D3C-355D-4C79-A839-9837122B2E2D_zps
just ordered a short shift of a nice chap on here and have also got a gearbox to gearbox brace coming from seat, plans are to fit some 264 newman cams and see if theres anything I fancy doing after.
Probably missed loads from copying images across from other places.
thanks for reading
Louis
Edited by havenhand
Small update on this..
ordered a gearbox to gearbox mount brace from seat... normally used for the cable change conversion. sure you can buy them without clutch cable tab but couldn't find a part number on vagcat. Found out there obsolete to order new so the guy at seat had one that tps London had in stock sent up to Sheffield. winner.
309D0023-133D-4316-A63F-A8366A578F55_zps
Ended up running into a small problem, car wouldn't go into second gear all the way, ended up having to cut the cable change bolt down to sit flush with the bottom of where it sits captive and then file a good 8mm off the top of the metal part where the clutch cable fits, all clears and gear change back how it should be.
Also my short shifter came thanks to besters on here (cheers dude), going to get the shifter tower dropped this weekend and get the short shifter in its place.
1F4522D5-CE91-4207-9F64-A402C95C7DC0_zps
thanks
Louis
Spent an hour on the car this afternoon and got my short shifter kit fitted, wasn't sure how this would go and had a go according to what the guide said, easy peasy job just had to file a tiny bit out of the car to slide the main pin out, gear shift feels along more positive and a lot shorter! winner winner..
23A2625E-E80A-4FF2-8A2D-CCA4F03EAF9C_zps
85A720DF-DEB5-4AEE-80F9-A7827CA64669_zps[
12AD7BD7-3BA0-46D3-8B81-7A767C52C9D2_zps
tiny bit I had to file.. noting major and hardly noticeable.. for the sake of 55 quid id highly recommend one...
978520B3-9F25-4DE9-AB15-7AAB75727807_zps
Also bought a genuine centre console for the electric windows as mine had a rubbish aftermarket panel bolted in, re wired all the windows which was a small job and modified the console near the shifter so it fitted easier over the tower, bish bash bosh all sorted..[
C38FA06A-078D-487D-AF84-19C336944B71_zps
URL=http://s916.photobucket.com/user/louismop1/media/7646207B-DC58-46F7-B50D-0FF8A2EF8835_zpsne1ho9qj.jpg.html]7646207B-DC58-46F7-B50D-0FF8A2EF8835_zps
cheers Louis
Edited by havenhand
Small update
The mk3 clocks in the car are a pretty naff fit and kept falling out of place behind the dash and just generally being a nuisance.
Wrapped some loom tape neatly round the right had side to stop the clocks falling out then tactically cable tied the other side in to stop that side moving about, not the prettiest fix but the clocks sit a lot more central and don't fall out anymore!
FCC555C3-6E61-4BD9-A2B6-08CABD6D4EF0_zps
4F1C4A4A-3C60-44BB-98B2-D2ACEEDCB925_zps
D7FC949C-A101-4D84-96A6-FFE4790F5E8D_zps
Forgot to take a picture with the front dash plastic back on, actually started the job to replace a blown bulb but thought I may aswell get the clocks sat the best I can.
Cheers louis
