vdub_pete 15 Posted July 14, 2014 Report Share Posted July 14, 2014 What's the worst job you've done on your vr? Anyone inclined to agree the piston rings are a real headache the oil scraper rings have the strength much less than that of a tooth pick!Sent from my iPhone using Tapatalk Link to post Share on other sites
Reaperx 181 Posted July 14, 2014 Report Share Posted July 14, 2014 Mine was heater matrix so far but rebuilding engine soon so that could change. Link to post Share on other sites
sep 68 Posted July 14, 2014 Report Share Posted July 14, 2014 keeping rust at bay... Link to post Share on other sites
Lukey. 381 Posted July 14, 2014 Report Share Posted July 14, 2014 Definitely heater matrix, it should not be that difficult to change a radiator! D11PS 1 Link to post Share on other sites
VR6Pete 1,455 Posted July 14, 2014 Report Share Posted July 14, 2014 Heater matrix is a pain. But using the knowledge vault article makes it easier to complete. Club Chairman Link to post Share on other sites
Reaperx 181 Posted July 14, 2014 Report Share Posted July 14, 2014 I think the problem with the matrix job is once you get it out there is that brief moment where you think all that effort for such a small part. Then you swear a little have a cigarette then refit it. Link to post Share on other sites
sedge 7 Posted July 14, 2014 Report Share Posted July 14, 2014 I didn't think heater matrix was too bad but mines a mk2 golf, maybe that makes it a bit easier?Re-fitting the drivers side wishbone after putting power flex bushes in was by far the most frustrating job for me, the locating washers and spacer tube are an absolute nightmare to fit! Well worth the effort though that said. D11PS and leespiro 2 Link to post Share on other sites
vdub_pete 15 Posted July 15, 2014 Author Report Share Posted July 15, 2014 Guess I was lucky then heater matrix had already been done when I bought my vr What's the deal with them anyway do they leak and piss coolant all over your legs or just not chuck out heat or what?Sent from my iPhone using Tapatalk Link to post Share on other sites
Reaperx 181 Posted July 15, 2014 Report Share Posted July 15, 2014 Mine had corroded over the years so every time the car got warm it misted up the inside of the windscreen. Link to post Share on other sites
Lukey. 381 Posted July 15, 2014 Report Share Posted July 15, 2014 The plastic inlet/outlet had fatigued on mine and blew off one day, covered me in hot coolant little bastard Link to post Share on other sites
Reaperx 181 Posted July 15, 2014 Report Share Posted July 15, 2014 The plastic inlet/outlet had fatigued on mine and blew off one day, covered me in hot coolant little bastardMine wasn't that bad but couldn't see where the fuck I was going I got half way down a motorway when mine first went that was a interesting drive home. Link to post Share on other sites
Vman 2 Posted July 15, 2014 Report Share Posted July 15, 2014 Touch wood I've only ever has a thermo stat stick shut Link to post Share on other sites
craggsy 91 Posted July 15, 2014 Report Share Posted July 15, 2014 Scrapping it was the hardest thing to do after owning it for 6 yrs+ Link to post Share on other sites
damian8588 11 Posted July 15, 2014 Report Share Posted July 15, 2014 My worst job so far has been removing the underseal takes ages Link to post Share on other sites
Grrrrallye 17 Posted July 15, 2014 Report Share Posted July 15, 2014 At the moment, stripping out the coolant hoses that have not been touched for over 20 years. Broken countless cable clips and retainers, had to strip out the air box, upper and lower inlet manifold, broken the crack pipe, ripped hands and arms to bits and swallowed about 5 pints of rusty coolant. Still should be worth it when i box them off to Forge damian8588, VR6Pete and daveyboy 3 Link to post Share on other sites
The Monk 50 Posted July 18, 2014 Report Share Posted July 18, 2014 The chuffing gearbox. It got boring. I had 2 mk3 VR6 over 4 years.Had the gearbox off a total of 7 times. Inferior parts/clutches and my tendency to launch her more times than pull away normally. Oil seal went on both engines, 3 clutches, layshaft/gearbox input shaft bearing aaaaaaaand a noobie/moron moment where I didn't tighten one of the flywheel bolts, resulting in a recovery. Driveshaft bolts annoyed me too.Did them all without a ramp, 1 jack to support the engine, me sprawled over the engine bay and lifting the buggers off and on again.Oh, the other arse ache.... replacing and realigning the rear engine mount Link to post Share on other sites
michael5556 247 Posted July 22, 2014 Report Share Posted July 22, 2014 It's got to be taking the sump off.... sleepymike 1 Link to post Share on other sites
abvsean 32 Posted July 26, 2014 Report Share Posted July 26, 2014 ignition switch!!!! killer job then probably welding new petrol tank filler neck bracket up inside the wheel arch Link to post Share on other sites
Lukey. 381 Posted July 26, 2014 Report Share Posted July 26, 2014 I think possibly the worst job is selling it, I look at it every day and just know it's going to have to go, it's like I'm interviewing them to see if they will do a good enough job of continuing this cars legacy, not gonna fucking rust paint the bonnet and put a set of pink banded steels on it and a kiddies trike and miners lamp on the roof. abvsean 1 Link to post Share on other sites
daveyboy 897 Posted July 26, 2014 Report Share Posted July 26, 2014 I think possibly the worst job is selling it, I look at it every day and just know it's going to have to go, it's like I'm interviewing them to see if they will do a good enough job of continuing this cars legacy, not gonna fucking rust paint the bonnet and put a set of pink banded steels on it and a kiddies trike and miners lamp on the roof.Well you know what to do mate........ just keep it damian8588 1 Link to post Share on other sites
Lukey. 381 Posted July 26, 2014 Report Share Posted July 26, 2014 It's not really an option like I've said I wish it was, I've got my harewood tickets booked today so it's definitely with me till then, maybe one last hurrah and I can adopt my child away to someone. (The golf not my actual child) Link to post Share on other sites
daveyboy 897 Posted July 27, 2014 Report Share Posted July 27, 2014 It's not really an option like I've said I wish it was, I've got my harewood tickets booked today so it's definitely with me till then, maybe one last hurrah and I can adopt my child away to someone. (The golf not my actual child)Good lad did you get the stand pass? Link to post Share on other sites
Lukey. 381 Posted July 27, 2014 Report Share Posted July 27, 2014 Yea that's what reminded me to get the tickets ordered daveyboy 1 Link to post Share on other sites
