zeph_becks 1 Posted August 22, 2014 Report Share Posted August 22, 2014 Hey guys, this is my first post on this site, i own a 94 golf vr6 ive owned it for one day and when ive been sitting at a red light if i dont feed it revs the engine will shut off randomly, it will start back up again fine but i really want to find the problem before it becomes worse, cheers guys! Link to post Share on other sites
Therusterman 59 Posted August 22, 2014 Report Share Posted August 22, 2014 Been a '94 car it will have an idle stabilisation valve, this may need cleaning out and/or replacing. Other than that, I'd get the fault codes read if possible-you can pick up generic code readers cheap off eBay. Link to post Share on other sites
zeph_becks 1 Posted August 22, 2014 Author Report Share Posted August 22, 2014 As im new to a vr6 engine, i have no idea where the idle stabilisation valve is located, would you be able to explain where located? Link to post Share on other sites
Therusterman 59 Posted August 22, 2014 Report Share Posted August 22, 2014 (edited) Should be around the back of the throttle body, number 1 in the image below Edited August 22, 2014 by Therusterman Link to post Share on other sites
zeph_becks 1 Posted August 22, 2014 Author Report Share Posted August 22, 2014 Okay thanks for that! Ill check it out Link to post Share on other sites
