smithy86 7 Posted August 22, 2014 Report Share Posted August 22, 2014 Hi guys,i went to start my car tonight and it fired but then cut out.It did this a few times so I got my (cheap ebay) vag code reader out and it came back with the code 17978 which I have read is something to do with the immobiliser.Can anyone shed any light on this and how it is sorted.I had another go at starting it 30 minutes later and it started fine. Link to post Share on other sites
Therusterman 59 Posted August 22, 2014 Report Share Posted August 22, 2014 Have a read of this, could be of some help; http://wiki.ross-tech.com/wiki/index.php/17978/P1570/005488 Link to post Share on other sites
smithy86 7 Posted August 22, 2014 Author Report Share Posted August 22, 2014 thanks mate..i did read something about c2 motorsport being able to erase the immobiliser of the ecu,how true this is I don't know. Link to post Share on other sites
UnitedMotorsport 55 Posted August 22, 2014 Report Share Posted August 22, 2014 We can turn the immo off, no problem. Link to post Share on other sites
smithy86 7 Posted August 22, 2014 Author Report Share Posted August 22, 2014 We can turn the immo off, no problem.how much would this cost and how would I go about it? Link to post Share on other sites
CALICO 130 Posted August 22, 2014 Report Share Posted August 22, 2014 I hope you have an alarm fitted if you remove the immobiliser. You should fix it/ remove it before it packs up altogether I replaced the ignition ring on mine and it was fine. Fairly cheap on ebay. Link to post Share on other sites
smithy86 7 Posted August 22, 2014 Author Report Share Posted August 22, 2014 yeah I don't want to leave it to long..i will see how much it costs to have the immobiliser removed and how they go about it otherwise im sure I will make small problem a big one Link to post Share on other sites
UnitedMotorsport 55 Posted August 22, 2014 Report Share Posted August 22, 2014 how much would this cost and how would I go about it?Send an email to info@unitedmotorsport.co.uk Link to post Share on other sites
smithy86 7 Posted August 23, 2014 Author Report Share Posted August 23, 2014 i gave the phirm a call and all sorted Link to post Share on other sites
Therusterman 59 Posted August 23, 2014 Report Share Posted August 23, 2014 What's the plan then? Link to post Share on other sites
smithy86 7 Posted August 23, 2014 Author Report Share Posted August 23, 2014 well after reading some info on the net and seeing that some people have fixed it only for the problem to return i have decided to have the immobiliser erased of the ecu. Link to post Share on other sites
Russvrt 85 Posted August 23, 2014 Report Share Posted August 23, 2014 You could just fit an immobiliser emulator ,costs a lot less that having it removed, Link to post Share on other sites
