FrankoVR6 0 Posted May 28, 2005 Report Share Posted May 28, 2005 Hi AllMy drivers-side rear window is Stuck at the down position.Im having trouble diagnosing what is wrong.It wont make any whirrs or clicks when i press either the door up/down button or the console up/down button.Is there any way I can get the window up Manually?? Its a bit of security risk, having my window down all the time.I've got the door skin off this morning, and I cant see anything unusual. (pinched wires etc).Please help, Im unsure what to do next! Franko Link to post Share on other sites
Eat this 2 Posted May 28, 2005 Report Share Posted May 28, 2005 iirc i had to remove the glass from the runner mechanism and brace it with a cpl of planks of wood lol that was the front window i dont know if rears r the same Link to post Share on other sites
acf8181 0 Posted May 28, 2005 Report Share Posted May 28, 2005 unplug the wiring from the motor, and then run a direct feed off a battery to the connections on the motor...if you do ti the right way round the window wil either go up (proving a wiring/switch fault), or won't do anything (proving the motor has had it) Link to post Share on other sites
Eat this 2 Posted May 28, 2005 Report Share Posted May 28, 2005 have a sniff of the motor mine STANK REALLY BAD burnt itself to a crisp i got a full mechanism from a scrap yard for Link to post Share on other sites
Petesvw 0 Posted May 28, 2005 Report Share Posted May 28, 2005 Try the switch from the other side, then you will know if its motor or switch. Also check the feed into the door, could be a broken wire. Link to post Share on other sites
