might3 0 Posted March 26, 2004 Report Share Posted March 26, 2004 Just bought a Vr6 Golf and it's simply awesome. May be in need of a new coil pack though. Can anyone suggest where the best place to buy from would be? I live in essex. Link to post Share on other sites
might3 0 Posted March 26, 2004 Author Report Share Posted March 26, 2004 have just been quoted £130 inc Link to post Share on other sites
acf8181 0 Posted March 26, 2004 Report Share Posted March 26, 2004 thats cheap, vw usually want £200 Link to post Share on other sites
nickbee 1 Posted March 26, 2004 Report Share Posted March 26, 2004 No further suggestions on the coilpack, £130 is a good price.However, since you're from Essex might I point you toward this link before Binliner does!Oh, and welcome! Link to post Share on other sites
might3 0 Posted March 26, 2004 Author Report Share Posted March 26, 2004 Link does not work Link to post Share on other sites
ingham 5 Posted March 26, 2004 Report Share Posted March 26, 2004 i think the link is on about using silicone grease to insulate coil pack to stop it arking,it works ,but only put on case not on leads Link to post Share on other sites
jcorallo 0 Posted March 26, 2004 Report Share Posted March 26, 2004 link is http://www.jct29.com/ Link to post Share on other sites
jcorallo 0 Posted March 26, 2004 Report Share Posted March 26, 2004 oh, and you can get a coilpack from either:1) GSF Thurrock2) EuroCarparts (Rayliegh or Chelmsford, Wood Green)3) VAGCheers,Jules Link to post Share on other sites
apd 0 Posted March 26, 2004 Report Share Posted March 26, 2004 any cracks/leaks-coilpack is shagged,tryed silicone sealing and supergluing plug seats-ok for awhile,but then back to square 1.new coilpack from GSF 137 QUID.solved that soft/faint misfire{spark arcing}. Link to post Share on other sites
might3 0 Posted March 27, 2004 Author Report Share Posted March 27, 2004 What I've got is a full on in your face misfire gradually getting worse. Have read about dodgy coil packs so will try first to see if it is. Can get it looked at by proffessionals but am strapped for cash at the moment. Link to post Share on other sites
ingham 5 Posted March 27, 2004 Report Share Posted March 27, 2004 what are your plugs like?how old ,mileage . Could be a lead try looking when its dark,sould see arc when u rev up[ Edited Sat Mar 27 2004, 06:08PM ] Link to post Share on other sites
jamieVR6 0 Posted March 27, 2004 Report Share Posted March 27, 2004 I've read about missfires on the vr6 engine & nothing i've read is good. It seems that they damage quite easily when missfiring, get it looked at sharpish before u've to buy a dustpan & brush to sweep the bits up when it goes BANG! Link to post Share on other sites
might3 0 Posted March 27, 2004 Author Report Share Posted March 27, 2004 L reg 80,000 miles. Serviced about 2000 miles ago. Leads don't look too old. Can't hear any arcing noises. Will have a look in the dark to see if I can see any arcs. The box does look crappy and full of cracks[ Edited Sat Mar 27 2004, 06:22PM ] Link to post Share on other sites
apd 0 Posted March 27, 2004 Report Share Posted March 27, 2004 bit of friendly advice:have a good look at each plug lead for cuts tears[20quid each from dealer].then take off plug leads with plug still attached.get a mate to crank engine-any arcing? should be nice blue spark.if everything ok this points to coil pack,once damp/moisture gets in through cracks unit shagged.got my old one you could try.silicone sealed ,where u at? Link to post Share on other sites
VR6Steve 0 Posted March 27, 2004 Report Share Posted March 27, 2004 If you end up changing leads, make sure you buy quality items. VAG is about £80 a set. Beware some performance leads are thicker and the channels the leads slot into need to have the securing lugs filed out. Link to post Share on other sites
jcorallo 0 Posted March 27, 2004 Report Share Posted March 27, 2004 If you end up changing leads' date=' make sure you buy quality items. VAG is about £80 a set. Beware some performance leads are thicker and the channels the leads slot into need to have the securing lugs filed out. [/quote']...and if you dont file them out, the sharp teeth in the slots cut into the soft silicone body of the leads and ruins them..... :@ Jules Link to post Share on other sites
VR6Steve 0 Posted March 27, 2004 Report Share Posted March 27, 2004 Jules, that sounds like the voice of (painful) experience? Link to post Share on other sites
jcorallo 0 Posted March 27, 2004 Report Share Posted March 27, 2004 Yes - bought some 'performance silicone' leads from GSF and the teeth bit right into all of them leaving little 5mm long splits in the leads.Back they went to GSF with the explanation - and top people - they gave me my money back.So I try and get standard ones whenever needed...!Jules Link to post Share on other sites
VR6Steve 0 Posted March 27, 2004 Report Share Posted March 27, 2004 With you there, i did buy some thicker leads and took them back. I did not fancy taking the lugs off as i worried about them being secure and also the fact of not being able to go back to standard thickness leads if i wanted to. Link to post Share on other sites
might3 0 Posted March 28, 2004 Author Report Share Posted March 28, 2004 Just had a look at the leads and noticed splits in the rubber. Can't see any arcing from the splits though. Obviously need changing anyway but does anyone think this would be enough to cause misfire? Link to post Share on other sites
ingham 5 Posted March 28, 2004 Report Share Posted March 28, 2004 could be,mine was plugs and they werent old Link to post Share on other sites
VR6Steve 0 Posted March 28, 2004 Report Share Posted March 28, 2004 might3 - as a temporary measure, try putting some electrical insulation tape around the splits. It may help til you get some new leads. Link to post Share on other sites
apd 0 Posted March 28, 2004 Report Share Posted March 28, 2004 had same problem as mighty3.splits in leads/cracks in coilpack casing.changed plugs & leads-still misfiring.silicone sealed coilpack-still misfiring.changed coilpack-SORTED.it"s a process of elimination,I aint spending money if I don't have to!using splitfire leads and not vw-no problems. Link to post Share on other sites
