Cooz93 66 Posted November 7, 2014 Report Share Posted November 7, 2014 (edited) Hi guys, looking to rebuild the VR for future turbo build, I've done a search and came across a few sites. Bar tek. Uro tuning etc. But I'd like recommendations/experiences from people that have used certain companies. Want to make sure im buying quality parts. And by 'rebuild' im talking abut chains/tensioners, thicker headgasket, head bolts etc. Stem seals are also shot. Cheers boys:) Edited November 8, 2014 by Cooz93 Link to post Share on other sites
ibs 308 Posted November 8, 2014 Report Share Posted November 8, 2014 (edited) I'm in the middle of a turbo build at the moment and had a look into it all just like you are doing. I've bought the following: Febi timing chain kit bought from my local Bennetts store as they came out the cheapestArp head bolts bought online from H-tuneStem seals came in the Elring head gasket set which also has the intake manifold gasket and exhaust manifold gasket. This set though did not come with the metal head gasket so I ordered 2 metal gaskets separately from Vince @ Stealth. Hope this helps you! Edited November 8, 2014 by ibs Link to post Share on other sites
Cooz93 66 Posted November 8, 2014 Author Report Share Posted November 8, 2014 Nice one. Cheers for that mate. Could you tell me there you got the elring head gasket set that came with the seals? Link to post Share on other sites
ibs 308 Posted November 8, 2014 Report Share Posted November 8, 2014 Ordered that from Bennetts as well. Could probably get you the part number off it when I go to my garage later. Link to post Share on other sites
Cooz93 66 Posted November 8, 2014 Author Report Share Posted November 8, 2014 That would be ideal mate if you don't mind. Fire me a PM later when you find out. Cheers:) Link to post Share on other sites
ibs 308 Posted November 8, 2014 Report Share Posted November 8, 2014 Will do. Link to post Share on other sites
ibs 308 Posted November 8, 2014 Report Share Posted November 8, 2014 Here you go mate... Link to post Share on other sites
Cooz93 66 Posted November 9, 2014 Author Report Share Posted November 9, 2014 Perfect, cheers for that. Appreciate it! ibs 1 Link to post Share on other sites
Cooz93 66 Posted August 18, 2015 Author Report Share Posted August 18, 2015 Bumping this as I'm away to starting sourcing parts for my rebuild. So..1. Best place to buy?2. What will I need? Will the valves/springs be alright?3. Piston rings? 4. Which headgasket? 5. Timing chain/ tensioner??What have people done before when rebuilding the top end..Info appreciated:) Link to post Share on other sites
chippy 34 Posted August 19, 2015 Report Share Posted August 19, 2015 I just finished up building my top end, I got my parts from https://vr6parts.com/ (schimmel performace) over in the states. They got pretty much everything you need to rebuild a VR I got the following from then: titanium springsretainersstem sealshigh flow water pumpARP flywheel studsSP 263 cams fairly reasonable prices but you do have to pay customs tax which is a bit. I got genuine OE lifters off ebay though. Headgasket I opted for the MK4 V6 triple metal layer one Cooz93 1 Link to post Share on other sites
ky_uk 304 Posted August 19, 2015 Report Share Posted August 19, 2015 That website is quality Link to post Share on other sites
Cooz93 66 Posted August 19, 2015 Author Report Share Posted August 19, 2015 Looks good chippy. What sort of delivery time was there from ordering to door? Unsure what I really want to replace. I know stems and chains will be done. But do I go as far as guides valves and springs? Won't be big power, possibly some cams but staying N/A.. Link to post Share on other sites
chippy 34 Posted August 19, 2015 Report Share Posted August 19, 2015 (edited) I think it was about 1-2 weeks, not entirely sure to be honest! I personally would change them just for piece of mind and since you intend putting cams in, you might as well change them. Also depends on what cams you choose also, 268s im pretty sure you would have to upgrade the springs. My guides had seen better days to be honest, stems where fine though. Edited August 19, 2015 by chippy Cooz93 1 Link to post Share on other sites
Cooz93 66 Posted August 19, 2015 Author Report Share Posted August 19, 2015 Alright cool. Maybe worth changing then. Did you also do your chains at when you done your head? Link to post Share on other sites
chippy 34 Posted August 19, 2015 Report Share Posted August 19, 2015 Yes, be crazy not to! lol Cooz93 1 Link to post Share on other sites
Cooz93 66 Posted August 19, 2015 Author Report Share Posted August 19, 2015 Ye your right. Just priced everything up except lifters and it's coming in significantly cheaper than it was within the UK. Even if I get raped on import taxes I should still make a big saving. Cheers for the advice Link to post Share on other sites
ky_uk 304 Posted August 19, 2015 Report Share Posted August 19, 2015 Here is a rebuild question, what can I use to remove all the grime and oil and 100000 miles of crap from the engine and gearbox ? Link to post Share on other sites
Cooz93 66 Posted August 19, 2015 Author Report Share Posted August 19, 2015 Engine out or still in place? Link to post Share on other sites
ky_uk 304 Posted August 19, 2015 Report Share Posted August 19, 2015 Engine out Link to post Share on other sites
daveyboy 897 Posted August 20, 2015 Report Share Posted August 20, 2015 Gunk and a jet wash ky_uk and D11PS 2 Link to post Share on other sites
alex williams 20 Posted August 20, 2015 Report Share Posted August 20, 2015 Did mine with engine in. But getting the box out on my drive was a struggle! Also mentioned above was upgraded springs, I have the schrick 268 cams and don't notice any valve bounce. Should I have uprated them? Link to post Share on other sites
Cooz93 66 Posted August 20, 2015 Author Report Share Posted August 20, 2015 Did mine with engine in. But getting the box out on my drive was a struggle! Also mentioned above was upgraded springs, I have the schrick 268 cams and don't notice any valve bounce. Should I have uprated them?Unsure on springs, but did you have any issue with valve guide clearances with the cams? Or did you just swap the cams over and it was good to go? Link to post Share on other sites
alex williams 20 Posted August 20, 2015 Report Share Posted August 20, 2015 No problem with clearances. Fitted them and was all gravy! Try to make up a plate to time the cams though, the tools are waaaay overpriced. I used a coilover C spanner and it was perfect! Lol. Don't recommend that to anyone though. Link to post Share on other sites
Cooz93 66 Posted August 20, 2015 Author Report Share Posted August 20, 2015 Nice One. I got an eBay special for 8.99 posted. Looks quality made aswel Link to post Share on other sites
ky_uk 304 Posted August 21, 2015 Report Share Posted August 21, 2015 Nice One. I got an eBay special for 8.99 posted. Looks quality made aswellove them eBay specials. Link to post Share on other sites
