HarrisVr 25 Posted July 8, 2016 Author Report Share Posted July 8, 2016 The vehicle is on the road of course long time now but due to the fact that i was abroad for a long time ,i didn't had the chance to examine bit by bit again what is the issue exactly. Nevertheless , 2 days ago , i had re - done the inner loom and came out like this >: I do have 2 questions though , if anyone can help me @ you can see above that , there is a white plug (on the left) with red/black wire from U1 AND U2 PLUGS , where does it go ? when i switch on (turn key ) i get 12 Volts. On the below picture i found a white plug again with green/brown wire which goes to the engine loom ,any ideas? Link to post Share on other sites
HarrisVr 25 Posted July 10, 2016 Author Report Share Posted July 10, 2016 (edited) Anyone ?? Edited July 12, 2016 by HarrisVr Link to post Share on other sites
HarrisVr 25 Posted July 13, 2016 Author Report Share Posted July 13, 2016 some more goodies ............................... Lamda sensor and crankshaft sensor Link to post Share on other sites
HarrisVr 25 Posted July 16, 2016 Author Report Share Posted July 16, 2016 (edited) received yesterday IT'S BEEN A LONG TIME DREAMING ABOUT THOSE .................. PSS9 :):) Edited July 16, 2016 by HarrisVr daveyboy, c00k, VR6Pete and 1 other 4 Link to post Share on other sites
HarrisVr 25 Posted August 4, 2016 Author Report Share Posted August 4, 2016 On 09/07/2016 at 0:13 AM, HarrisVr said: The vehicle is on the road of course long time now but due to the fact that i was abroad for a long time ,i didn't had the chance to examine bit by bit again what is the issue exactly. Nevertheless , 2 days ago , i had re - done the inner loom and came out like this >: I do have 2 questions though , if anyone can help me @ you can see above that , there is a white plug (on the left) with red/black wire from U1 AND U2 PLUGS , where does it go ? when i switch on (turn key ) i get 12 Volts. On the below picture i found a white plug again with green/brown wire which goes to the engine loom ,any ideas? any help on the above is appreciated , thanks Link to post Share on other sites
boab3 164 Posted August 6, 2016 Report Share Posted August 6, 2016 the other cables from the u1/u2 loom is for the tranny selector P R D N etc etc and the other is for the bootlid when its open and ,Break Pad Wear Indicator Link to post Share on other sites
boab3 164 Posted August 6, 2016 Report Share Posted August 6, 2016 Green and brown with white plug in can't remember I'll try find out Link to post Share on other sites
HarrisVr 25 Posted August 6, 2016 Author Report Share Posted August 6, 2016 8 hours ago, boab3 said: Green and brown with white plug in can't remember I'll try find out i am curious 13 hours ago, boab3 said: the other cables from the u1/u2 loom is for the tranny selector P R D N etc etc and the other is for the bootlid when its open and ,Break Pad Wear Indicator thanks for the tip Link to post Share on other sites
HarrisVr 25 Posted September 14, 2016 Author Report Share Posted September 14, 2016 I think i found the issue , something is wrong with my throttle body ,does anyone know the degree (angle) of the throttle butterfly??? I found it 9.6 degree angle , is it correct??? Link to post Share on other sites
c00k 435 Posted September 14, 2016 Report Share Posted September 14, 2016 (edited) You can re-aline the throttle body using vag-com. Im not sure of the angle off the top of my head sorry, but re-alining it with vag-com should solve any angle issues. Edited September 14, 2016 by c00k Link to post Share on other sites
HarrisVr 25 Posted September 15, 2016 Author Report Share Posted September 15, 2016 Thank you for your reply , actually i tried once but it was not with Vagcom ( something else i don't remember right now) but when i did it ,it took like 30 minutes and at the end the Program crashed ( ) . Anyways i will figure it out somehow . Link to post Share on other sites
VR6CABBS 1,311 Posted September 15, 2016 Report Share Posted September 15, 2016 You can go down the cheap route with vagcom too. Just buy a cheap vagcom cable from eBay and download the lastest version vcds from there website. It's free. But make sure your laptop IS NOT connected to the Internet when using it because it will null your cable. Link to post Share on other sites
HarrisVr 25 Posted September 15, 2016 Author Report Share Posted September 15, 2016 a bit of update besides my small engine issue , at least i am trying to do something good boab3 1 Link to post Share on other sites
HarrisVr 25 Posted May 18, 2017 Author Report Share Posted May 18, 2017 just a video (part1 ) of all the above so far for my golf 2 Link to post Share on other sites
