stevenml 1 Posted November 24, 2014 Report Share Posted November 24, 2014 There are many threads on the topic. Most of them are not that current. I placed it in this section because my question is overall performance, tuning and ongoing costs after the build. Goal is round 450 whp with a longitudinal 01e tranny. Standalone ecu. Plan to get a built engine but having a challenge between the 12v and 24v. I can see pros and cons to both. Thanks in advance Steven Link to post Share on other sites
RBPE 198 Posted November 25, 2014 Report Share Posted November 25, 2014 Stand alone pants, oem ecu far better. Newer the engine/ecu, the more advanced the features are but then it depends on the mapper and/or what parts you are using - it would be pointless mapping in the variable resonance manifold features of the ecu if you changed to a SRIM! Etc. Costs roughly the same - you pay for what you get. 450hp - either engine - ARP rod bolts, head studs, spacer plate and if your engine is in bits then new rings, bearings etc, stock rods have done 700+hp, pistons have been known to blow but older engines need refreshing and tolerances renewing which would more likely explain the cause rather than having to upgrade to new pistons - does help though if you want to negate the spacer route. If money was no object, I would personally use an FSI R32 but that's only because of the sheer scale of map functions in the ecu compared to the older ones - either 12v or 24v would do you for 450hp, better/full VVT on the newest 24v but depends on the map you use! Link to post Share on other sites
