OBD1 vr6 ABV Mk3 Golf, best mods for increasing torque :)
I have recently finished converting my Mk3 16v to 2.9 ABV engine with OBD1 AAA loom, ECU, throttle body and MAF. I also have a K&N panel filter, and 2.25 cat back stainless exhaust system.
I'm not bothered about top end speed or bhp figures, but usable 0-60 power and torque! What are the best best mods for me?
I have a decat and 2.9 TB yet to fit, and I want to get the ecu remapped, but what else can I do without forced induction?
The thin metal head gasket to rais compression a little
Clean up the exhaust manifolds a little
You can grind out the weld on the inside of the downpipe then re weld on outside and gasket match the ports
If you do the head gasket may as well do stem seals and clean up the inlet ports with some 80grit and polish the exhaust ports
What's the budget??
