Antihero1981 8 Posted December 2, 2014 Report Share Posted December 2, 2014 Hi , so I attempted the vcds on the vento obd2 vr6 and it came up with the following ,not fussed about the abs stuff but worried why I cant connect to the engine and the auto trans code anyone got any ideas? could not scan the engine , tried a few times kept coming up excessive comms errors VCDS-Lite Version: Release 1.0Tuesday, 02 December 2014, 17:06:22:0Chassis Type: 1H - VW Golf/Vento IIIScan: 01,02,03,08,12,15,25,41,56 -------------------------------------------------------------------------------Address 01: Engine Labels: 01M-927-733.LBL Controller: 021 906 256 Note: Excessive Comm Errors-------------------------------------------------------------------------------Address 02: Auto Trans Labels: 01M-927-733.LBL Controller: 01M 927 733 CT Component: AG4 Getriebe 01M 3363 Coding: 00000 Shop #: WSC 000001 Fault Found:00518 - Throttle Position Sensor (G69) 16-10 - Signal Outside Specifications - Intermittent-------------------------------------------------------------------------------Address 03: ABS Brakes Labels: 3A0-907-379.LBL Controller: 3A0 907 379 E Component: ABS/EDS ITTAE 20 GI V00 Coding: 03704 Shop #: WSC 000002 Faults Found:00290 - ABS Wheel Speed Sensor; Rear Left (G46) 35-00 - -00287 - ABS Wheel Speed Sensor; Rear Right (G44) 35-00 - --------------------------------------------------------------------------------Address 15: Airbags Labels: 6N0-909-60x-VW2.LBL Controller: 6N0 909 603 E Component: AIRBAG VW2 V00 Coding: 00069 Shop #: WSC 013171 Fault Found:00532 - Supply Voltage B+ 07-10 - Signal too Low - Intermittent-------------------------------------------------------------------------------Address 25: Immobilizer Labels: 1H0-953-257.LBL Controller: 1H0 953 257 B Component: IMMO VWZ3Z0V3230127 V00 Coding: 09600 Shop #: WSC 00000No fault code found.End -------------------------------------------------------------------------------------------------- WelchFarf 1 Link to post Share on other sites
michael5556 247 Posted December 2, 2014 Report Share Posted December 2, 2014 16507/P0123/000291 - Throttle Position Sensor (G69): Signal too High Possible Symptoms Malfunction Indicator Light (MIL) ON EPC Light On Increased Idle Speed Bucking at Load Change Possible Causes Fuse(s) faulty Wiring and/or Connector(s) from/to Throttle Position Sensor (G69) faulty Throttle Position Sensor(s) Faulty Throttle Body dirty Throttle Body faulty Possible Solutions Check Fuse(s) Check Wiring and/or Connector(s) from/to Throttle Position Sensor (G69) Clean Throttle Body and complete TBA Check Throttle Body Wiring Check Throttle Body Check/Replace Throttle Position Sensor (G69) On DBW Vehicles This Includes Accelerator Pedal Position Sensor 1 (G79) and 2 (G185). On DBC Vehicles This Includes Throttle Position Sensor G69 and G88. Special Notes See Throttle Body Alignment (TBA) Use Meas. Blocks & Basic Setting for testing When found in the NAR 2.0l TFSI: (BPY, CCTA and CBFA) Check VW TSB 01-09-04 or 2018652 for a wiring repair at the Throttle Body. Check for proper seating at the ignition coils. When found in the NAR Audi 2.0l TFSI, 3.2L FSI and 3.6L FSI engines: Check Audi TSB 97-08-25 or 2018260/4 for a wiring repair at the Throttle Body. Link to post Share on other sites
Big J 283 Posted December 25, 2014 Report Share Posted December 25, 2014 развивающие бесплатные игры онлайн детские игры бесплатно скачать игры онлайн бесплатно триWhat he said Link to post Share on other sites
Big J 283 Posted December 25, 2014 Report Share Posted December 25, 2014 Is it just my tapatalk or am I missing something here?? Link to post Share on other sites
Bealieboy 1,625 Posted December 25, 2014 Report Share Posted December 25, 2014 (edited) Is it just my tapatalk or am I missing something here??Are you not also fluent in Russian big J? Sent from my iPhone using Tapatalk Edited December 25, 2014 by Bealieboy Link to post Share on other sites
Big J 283 Posted December 25, 2014 Report Share Posted December 25, 2014 Thank fuck for that I thought my turkey had been spiked! bennyk, VR6CABBS and Bealieboy 3 Link to post Share on other sites
VR6CABBS 1,311 Posted December 25, 2014 Report Share Posted December 25, 2014 Thank fuck for that I thought my turkey had been spiked!Well it also beats me. Even Fookin google translate hasn't got a clue. Lol. This could be terrorist related code work that's found it way onto VR6OC......Needs reporting to MI5 I reckon. LolSent from my iPhone using Tapatalk Link to post Share on other sites
Bealieboy 1,625 Posted December 25, 2014 Report Share Posted December 25, 2014 You've probably got the wrong dialect cabbs, you know, it's a bit like us boys from the south East and you blokes North of Watford for example, google translate doesn't work for us either! Sent from my iPhone using Tapatalk Link to post Share on other sites
Big J 283 Posted December 25, 2014 Report Share Posted December 25, 2014 Well it also beats me. Even Fookin google translate hasn't got a clue. Lol. This could be terrorist related code work that's found it way onto VR6OC......Needs reporting to MI5 I reckon. LolSent from my iPhone using TapatalkI rekon even MI5 would take one look and think "I'm sure this can wait until the 6th" Link to post Share on other sites
VR6CABBS 1,311 Posted December 25, 2014 Report Share Posted December 25, 2014 Watford??? Where's that??? Thought it was down south near you. I'm a lot more north than Watford pal. It's where real bargains take place and you southern vultures snatch our bargains. HahahahaSent from my iPhone using Tapatalk Link to post Share on other sites
Bealieboy 1,625 Posted December 25, 2014 Report Share Posted December 25, 2014 (edited) I have to look further away for bargains cabbs coz Bennyk has just about got this area sown up. Yeah Watford is only about 40mins from me, anything North of that is a long way! Hahaha Sent from my iPhone using Tapatalk Edited December 25, 2014 by Bealieboy Link to post Share on other sites
Big J 283 Posted December 25, 2014 Report Share Posted December 25, 2014 North wales too far then beal?? Link to post Share on other sites
Bealieboy 1,625 Posted December 25, 2014 Report Share Posted December 25, 2014 North wales too far then beal??Not for a real bargain! :-)Sent from my iPhone using Tapatalk Link to post Share on other sites
VR6CABBS 1,311 Posted December 25, 2014 Report Share Posted December 25, 2014 North wales too far then beal??North Wales is the other side of the country for Bealieboy. Wrexhams pretty close to me J. It's at the end of the M56 ain't it pal. Link to post Share on other sites
Bealieboy 1,625 Posted December 25, 2014 Report Share Posted December 25, 2014 Wrexham is 3hrs 40mins from me, I reckon your safe from the bealie magpie up there..... Unless I can courier a potential purchase! Sent from my iPhone using Tapatalk VR6CABBS 1 Link to post Share on other sites
Bealieboy 1,625 Posted December 26, 2014 Report Share Posted December 26, 2014 What is the language your using fella? Sent from my iPhone using Tapatalk Link to post Share on other sites
Big J 283 Posted December 26, 2014 Report Share Posted December 26, 2014 North Wales is the other side of the country for Bealieboy. Wrexhams pretty close to me J. It's at the end of the M56 ain't it pal.Yeah not too far off cabbs, 56, onto 53, just bypass Chester and it's pretty much wrexham shit hole from there on.I'm trying to bargain a set of wheels as we speak from a secret location, so you know that little "new wheels" thread""?? Watch this space...... Bealieboy and VR6CABBS 2 Link to post Share on other sites
Bealieboy 1,625 Posted December 26, 2014 Report Share Posted December 26, 2014 Do share big J, what have you found? Sent from my iPhone using Tapatalk Link to post Share on other sites
VR6CABBS 1,311 Posted December 26, 2014 Report Share Posted December 26, 2014 Yes share the love big lad. Christmas is a time for sharing!! Sent from my iPhone using Tapatalk Link to post Share on other sites
Big J 283 Posted December 26, 2014 Report Share Posted December 26, 2014 As soon as the deals agreed, il put up a pic for ya'll. but of a gamble on the colour but hey ho, I like to be different Link to post Share on other sites
Bealieboy 1,625 Posted December 26, 2014 Report Share Posted December 26, 2014 (edited) I wondered if it was the gotti's which have listed as sold today? Sent from my iPhone using Tapatalk Edited December 26, 2014 by Bealieboy Link to post Share on other sites
Big J 283 Posted December 26, 2014 Report Share Posted December 26, 2014 Nope, all I can confirm is they are a breed of the 17" variety VR6CABBS 1 Link to post Share on other sites
