Luke-VR6 0 Posted January 5, 2015 Report Share Posted January 5, 2015 Hi all, I'm starting to tackle some work on my vr6 over the coming weeks so i will probably be asking a few questions.Could someone please shed me some light on what these 2 plugs are? -Ones near the battery, the others coming from the engine?Cheers,Luke Link to post Share on other sites
Big J 283 Posted January 5, 2015 Report Share Posted January 5, 2015 See if you can trace them back mate and find out where they go too. Might help us to narrow it down a bit for you. Link to post Share on other sites
Luke-VR6 0 Posted January 5, 2015 Author Report Share Posted January 5, 2015 Heres the one from the back of the engine. Its looks like its either running to the circle thing with all the wires coming out (u can tell I'm a mechanic) or it runs round to the front somewhere.Its hard to tell.Sorry i know the photos arnt great, i will try get some better ones tomorrow. Link to post Share on other sites
Luke-VR6 0 Posted January 5, 2015 Author Report Share Posted January 5, 2015 The plug near the batter tray runs with aload of other wires into the scuttle area/interior.Could these be for foglights? I do have foglights but they dont work.Again sorry not giving much clarity on this, i will try tomorrow to trace them further.Thanks Link to post Share on other sites
vr6turbo 27 Posted January 5, 2015 Report Share Posted January 5, 2015 fog light connectors will be in the main headlight loomthe round connector tucked away to the left of the bonnet catch (standing facing the engine)the one near the engine could be the after run coolant pump can you here the pump working when you switch off the ignitionif not I noticed a vr6 with a sensor in the hose that leads to the heater matrix from the back of the cylinder headI have never seen this layout beforehere's a picit may be some thing to do with the electric airconhope this helps Link to post Share on other sites
c00k 435 Posted January 5, 2015 Report Share Posted January 5, 2015 Is this a standard engine bay, or and engine conversion some one has put in??The 2pin plug on the side of the engine is for auxiliary water pump I think. The one near where the large engine loom connects. The auxiliary water pump is just underneath the plastic house that holds the HT leads nears the coil pack. It has a 2 pin connector on the top. All headlights, fog lights, indicators wiring runs down the driver side chassis leg. So no where near the battery as standard. But if engine conversion could be different. Link to post Share on other sites
Luke-VR6 0 Posted January 5, 2015 Author Report Share Posted January 5, 2015 No its an original vr6 but i think its in a bit of mess, theres a few things wrong with it, it runs and drives fine but i probably paid a bit too much for it tbh. Loads of electrical problems and by the looks of it compared to other vr6 engine bays theres a bit of dodgy untidy wiring. No i've never hear the pump still going after switching off the ignition.Need to get an auto electrician down really.Do you know any in east london / essex (romford) area?And thanks for your help, r.appreciate it!I dont have aircon but maybe it did before Link to post Share on other sites
dj-madman 146 Posted January 5, 2015 Report Share Posted January 5, 2015 (edited) I'm not an expert but I work in thurrock mate, I could at some point pop over and have a butchers for you? Or when your doing your shopping I could always meet you? There are a few guys in Essex kent area. If that plug is for aux water pump it's easily sorted (famous last words) Up to you though fella I don't mind having a quick gander if it gets the girl running properly againSent from my GT-I9505 using Tapatalk Edited January 5, 2015 by dj-madman daveyboy and VR6CABBS 2 Link to post Share on other sites
Luke-VR6 0 Posted January 5, 2015 Author Report Share Posted January 5, 2015 That would be great only thing is shes only just been declared sorn. Mot is due and theres a good few bits i've got to do before hand to get a pass.But i mean if your ever near romford and can pop by for 20 minutes that would be wicked! Link to post Share on other sites
dj-madman 146 Posted January 6, 2015 Report Share Posted January 6, 2015 Not a problem luke ill see what I can do mateySent from my GT-I9505 using Tapatalk Link to post Share on other sites
