induction kits reccomendations
Sorry to thread jack, but
The carbon cannister - is that located below where the induction kit would be in between inner and outer wing (if you see waht i mean)
What does it do and is it needed etc? Would like to put a pipe in there to my induction kit from my lower bonrath grille.
Cheers!!
Thats the one - easy to remove & I've got exactly the set up your going for - theres still part of the air con in the way at the top of the Bonrath vent but you can make the feed fit - I noticed the difference straight away :0) See here for removal tips: http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?60632.post
