vento vr6 still not starting
Hi guys  still having issues with the vento , vr6 obd2 1997
so I have changed the following
new spark plus
new coil pack
new ignition switch
new crank sensor
new temp sensor
and the vento still just cranks and not fires , I took off the coil pack wiring plug and don't get any voltage with the ignition on , this does not sound right. where does the coil pack get power from ?
been 3 months and she is not running
what else can I check?
Looks like you are checking all the electrical side of things have you checked fuel pump etc ? Is the car priming the injectors ? My wife's raddo would t start and it ended up being the relays for the heated leather seats ? They were drawing soo much power from the battery , 60 amps that it stopped enough power from getting to the fuel pp relay ??
  • 1 month later...
