alex williams 20 Posted February 12, 2015 Report Share Posted February 12, 2015 Hi all, I've recently bought my first vr6 and been stitched up at every turn. Sorted most of the issues, but this one is troubling me, the clutch bite point is quite quickly making its way toward the floor as if the clutch travel is getting less and less. soon the biting point will be at the floor and I wont be able to shift gear. Could this be the clutch cable, release bearing, or something much worse??? Does anyone have any info or previous experience with this? any help would be greatfully recieved Many thanks in advanceAlex Link to post Share on other sites
Gilly17 51 Posted February 12, 2015 Report Share Posted February 12, 2015 Hi Alex I've got the same problem, but I haven't had time to sort it out yet!! I posted about it a few months ago and big j was very helpful. Go into vr6oc hangout, then discussion and type in "low biting point" into the search at the top of the screen (I am using tapatalk) then it should be the 8th one down. You should find this very helpful. alex williams 1 Link to post Share on other sites
alex williams 20 Posted February 12, 2015 Author Report Share Posted February 12, 2015 Cheers man, the pedal feels really slack until about 3/4 down so hopfully just the fluid needs bleeding Gilly17 1 Link to post Share on other sites
Gilly17 51 Posted February 12, 2015 Report Share Posted February 12, 2015 (edited) Hope so!! Easy fix Edited February 12, 2015 by Gilly17 Link to post Share on other sites
alex williams 20 Posted February 12, 2015 Author Report Share Posted February 12, 2015 Yea it would be a nice change in my luck. Gilly17 1 Link to post Share on other sites
daveyboy 897 Posted February 13, 2015 Report Share Posted February 13, 2015 (edited) If the clutch is goosed I'd expect the bite to be high and it'd more than likely be slipping. So I'd tend to lead towards the clutch needing bled Edited February 13, 2015 by daveyboy Link to post Share on other sites
Jimjon 28 Posted February 13, 2015 Report Share Posted February 13, 2015 Could be the clutch fork bending. daveyboy 1 Link to post Share on other sites
alex williams 20 Posted February 23, 2015 Author Report Share Posted February 23, 2015 It now seems the clutch slave cylinder has decided to dump all the nice new dot 4 i put in, i mean it was literally flowing out!! So my question(s) to you, the collective, what is the best or easiest way to fix this? does anyone know of anywhere that does a repaire kit / recon parts?? or is new from TPS the best way forwards? Also a rough ida on price would be nice so i know im not getting ripped off! Cheers Link to post Share on other sites
Gilly17 51 Posted February 23, 2015 Report Share Posted February 23, 2015 That's good news,,,,,,, in a way!!!at least it's not the clutch fork coz you have to take the box out. I'd fit new, you can pick up new slave cylinder on eBay for about £50 it is advised to fit a new master cylinder at the same time, their about £50 as well. Don't know how much a garage would charge to fit them. Link to post Share on other sites
alex williams 20 Posted February 23, 2015 Author Report Share Posted February 23, 2015 F paying a garage to do it, you never learn if you dont do it yourself!!! Gilly17 1 Link to post Share on other sites
