I'm looking at changing the piston rings on my 1994 vr6 at the same time as doing the head gasket & cylinder head rebuild but needed to check ,do you need to renew the bolts that hold the big end bearing caps on ?
and is it worth replacing the bearings at the same time? its only on 70k
I didn't change my bolts but I did replace the bearing caps when I recently did mine. It does not mention anywhere in the Bentley manual about having to change the bolts either.
On page 13.32 its notes the bolts as item no. 5 and says always replace.
Going to check my receipt for my bottom end and see if they were replaced or not.
Ok cheers mate!I'm tempted to just change the bearings then but was there a reason you changed the bearing caps as well? Just imagine they would be quite expensive !
Sorry bud I meant the actual bearings I replaced them not the caps.
Just had a look at that bit they are not referring to the bearing cap bolts. The bolt they are talking about is the crankshaft pulley bolt.
